Trail Brake Module Fault
Old Dec 30, 2024 | 07:07 AM
Electrified47's Avatar
Electrified47
I got in my truck the other day {2024 F350 with 1000 miles) and when I started it a "Trailer brake module fault" popped up. I press "OK" and it went away but comes up now every time I start it up. The truck runs fine but I also notice now that the blinker lights on the the dash flash really quick like in the old days when a turn bulb was out but the the outside front and rear blinker lights all seem to cycle at normal rate. Any suggestions before I head back to the stealer?
Old Dec 30, 2024 | 08:27 AM
CBEllis's Avatar
CBEllis
Do you have a trailer hooked up? If you do, do you use the Ford Pass app? There is a trailer light testing program that lets you control the lights from outside the vehicle, testing the brake lights, turn signals, etc. while walking around behind the truck & trailer. It's a pretty cool feature to use before hitting the road. But if there's a module fault, you may need something reprogrammed or replaced. I've personally never seen that warning message. But I have seen a trailer light fault message pop-up. Smart-a$$ trucks...
Old Dec 30, 2024 | 08:42 AM
willynilly's Avatar
willynilly
doesnt seem very smart if its already back at the dealer a 1000miles in
Old Dec 30, 2024 | 08:58 AM
CBEllis's Avatar
CBEllis
True - smart when it works the way it's intended. Just like any other truck.
Old Dec 30, 2024 | 09:15 PM
stroke250's Avatar
stroke250
Probably needs a software update(s).
Old Dec 31, 2024 | 07:15 AM
Electrified47
The issue ended up being the connector going to the trailer brake control module (right behind the emergency brake under the dash). It just needed to be re-seated. That also cured the rapid blinking turn signal.
wharthog
2015 - 2020 F150
Jan 16, 2026 06:35 PM
Jnsquires
6.7L Power Stroke Diesel
Nov 28, 2023 09:56 AM
93RangerXL4x2
1997 - 2003 F150
May 27, 2006 04:19 AM
jddun123
Jan 11, 2006 10:16 AM
johnnypopper720
Electrical Systems/Wiring
Jun 26, 2003 11:31 PM
