Fuel Pump
Old Dec 28, 2024 | 01:03 PM
95PSD73's Avatar
95PSD73
5th Gear
Fuel Pump
95 7.3 - replacing pump & rod at base of pump fell into engine. Turned pulley at alternator trying to turn cam & get it to drop into oil pan. After a few turns, it started to bind...assuming it's the rod binding the cam but not sure. Suggestions?
Old Dec 28, 2024 | 02:56 PM
97-psd's Avatar
97-psd
I would put a scope down in the hole and see what you are up against.
Old Dec 28, 2024 | 02:59 PM
95PSD73's Avatar
95PSD73
5th Gear
Turned crankshaft opposite direction a ways and heard rod fall into pan. Isn't the cam supposed to be marked somehow to set position for installing new pump?
Old Dec 28, 2024 | 03:08 PM
97-psd's Avatar
97-psd
Just get the the lobe to the top.
Old Dec 31, 2024 | 11:55 AM
95PSD73's Avatar
95PSD73
5th Gear
New fiel pump installed...still won't crank. Takes 10-12 cranks to fill fuel bowl but just won't turnover. Restriction? If so, where to start? Trips to the beer box starting early today😁. Open to any/all advice.
Old Dec 31, 2024 | 01:27 PM
knottyrope's Avatar
knottyrope
fuel pressure while cranking?
have any codes?
PCM fuse good?
Old Dec 31, 2024 | 01:56 PM
Harveyearlolstad's Avatar
Harveyearlolstad
Schraeder valve shooting out fuel while cranking?
Old Dec 31, 2024 | 03:06 PM
95PSD73's Avatar
95PSD73
5th Gear
Finally got it going and all seems normal...can't identify any reasons for such hard starting other than just air in system. I've just never experienced one that took so long to bleed air out.
Old Dec 31, 2024 | 05:25 PM
Edgethis's Avatar
Edgethis
It can take quite awhile to get the air out enough to start.
Hopefully it stays working and you can move onto the next project!
Old Dec 31, 2024 | 06:08 PM
95PSD73's Avatar
95PSD73
5th Gear
Thinking next project might the conversion to electric fuel pump😁.
arthall
Aug 31, 2020 09:49 AM
andydunks
Jan 16, 2015 06:00 AM
howdy71475
1947 and Older Ford Trucks
Mar 2, 2007 10:16 PM
bobj49f2
Jun 28, 2005 11:50 AM
willp
Feb 22, 2003 10:23 AM
