I have a 1986 F150 Lariat XLT Supercab and it currently has a 3 speed transmission. I inherited it from my stepdad and it only had 85k original miles when I started working on it. Unfortunately, it sat for 8 years so I've replaced many things already such as fuel tanks, lines, injectors, starter, solenoid, AC, etc., but I still have a slow main seal leak. I have a repair shop I trust, who said when its time, they'd do a total reseal of the motor for roughly $3k-$4k.
I started doing research and found where I could purchase a zero miles, above OEM rebuild for the same price. Given that I still hear knocking in my current motor, which now has 91k miles, wouldn't it make more sense to purchase the rebuilt motor with no miles? That's if I went with the same 5.0L 302 V-8, which only has a max HP of 290.
If me and the motor had any "knocking" a "full reseal" will not fix that just stop the leaks at least that is how I read it.
With that said I would go for 0 miles motor.
Now you say 3k to 4k to reseal so I am guessing they will be pulling it.
I cant see then spending the labor time to take it a parts for gaskets and still have a knock when they can just move, labor, the needed parts from the old motor to the new one and motor on.
So I think you can see I am for replace with 0 miles
Dave ----
Yep, get the new 302 and clutch kit and have that installed. My 302 crate motor installed back in Sept 1991 is doing great. It now has about 45.000 miles on it. The EFI works good with today's fuels.
EDIT, I'll add because at 96,000 miles the engine had a knock. I remember the day, when Dad stopped by as I was mowing the lawn. I shut off the mower as he was backing in the driveway. Before he shut the truck off, I could hear the knock from a few feet away. He bought the truck used with about 86,000 miles on it, was told they were mostly highway miles. Funny how somethings you never forget.
With the parts you have already installed replacing the engine will give you another 10 years of good service.
Especially if the body is solid.
Also a new radiator should be figured in.
Have you talked with a local auto machine shop to see what they can do with your engine. Sounds like you don't have much mechanical ability, or you would be asking how hard is it to remove the engine. If you have some ability, it should not be to hard as long as you have the space and tools.
I'm sure there are youtube video's on pulling the engine out of one of these.
The problem now is, a lot of shops are busy this time of year. There returning customers have their engine in being refreshed for the coming Spring time. But if you have the time, it would be a good way to go.
I’m missing something. Why would you have the engine removed for a “total reseal” when only the <$20 rear main is bad? Is there reason you aren’t considering only replacing the rear main seal? I don’t know what they would charge to R&R the transmission but I’d guess 6 hours labor so you are well
under $1K to fix the problem.
Motor has a knocking noise and my guess is the shop wants to pull the motor as it may have a rope seal so the rear main cap has to be dropped so the oil pan needs to come down.
That leaves the front cover & seal and valve covers, maybe the intake?
If the front cover is off then do a timing chain, but you still have the noise and a motor with how many miles?
Dave ----
Somehow I missed the knocking noise but is that coming from the engine or somewhere else? Maybe in the bell housing? A 302 should not be worn out with only 91K on the ticker unless stepdad abused it.
I definitely would be looking at a long block if the engine was determined to have a noise in the bottom end.
Not hearing the noise and the OP only telling us it has a noise we can only guess motor.
Could be a broken piston from spark knock or wrist pin noise.
If it was a main or rod it would be a really bad noise and no oil PSI in my book.
Dave ----
