Seafoam????
Old Dec 2, 2003 | 02:28 PM
460429_freak's Avatar
460429_freak
Question Seafoam????
I read a few post(about 6 months ago) where you guys used sea foam in your tranny to help it out where would you buy that at in MISSOURI??
Old Dec 2, 2003 | 02:37 PM
wrangler76's Avatar
wrangler76
seafoam
I believe there are two types of Seafoam... I've used the origional seafoam in my fuel and crankcase... then there's a seperate Seafoam for the tranny. It's at every NAPA around here.
Old Dec 2, 2003 | 04:45 PM
76390FE's Avatar
76390FE
wrangler76 is right...there is now a seafoam made just for transmissions. You should be able to find it at any auto parts stores, or any mechanic shops in your area. I have never used the stuff for the tranny but I have had good results with the regular seafoam in my crank case and fuel system.
Old Dec 2, 2003 | 06:13 PM
trouble's Avatar
trouble
O'reilly's carrys it . Both for gas tanks and trannys
Old Dec 2, 2003 | 07:01 PM
dbarracuda's Avatar
dbarracuda
What is seafoam and what is it supposed to do?
David
Old Dec 2, 2003 | 09:49 PM
Torque1st's Avatar
Torque1st
Posting Legend
It is a brand of mechanic in the can witch doctor's brew of solvents. One of those cure-all snakeoil deals.
Old Dec 2, 2003 | 11:53 PM
wick246's Avatar
wick246
I thought this was going to be a thread about turquoise paint.
Old Dec 3, 2003 | 06:57 AM
79oneton's Avatar
79oneton
seafoam tranny additive worked for me. NAPA stores
Old Dec 3, 2003 | 09:24 AM
beartracks's Avatar
beartracks
Try NAPA. I believe the engine treatment works for removing carbon. Most tranny treatments work by swelling the seals however and this tends to work initially but the swelling continues. If you were to flush the fluid after the treatment you would then stop the process. Of course this complicates things.
Old Dec 3, 2003 | 11:48 AM
Huntsman's Avatar
Huntsman
Seafoam gas treatment works good in outboard engines, when you let them sit a little longer than you should.
Old Dec 3, 2003 | 02:48 PM
Matts72's Avatar
Matts72
Most tranny additives like Lucas Oils make the seal swell, seafoam cleans out the crap that builds up in the small passages of your automatic transmission.
Yes, it works wonders, and I resent that anyone would consider it a snake oil.
NAPA, and Carquest carry the product.
Old Dec 4, 2003 | 05:58 PM
Born-n-raisedFord's Avatar
Born-n-raisedFord
im from cape Girardeau and the only places i can find it is napa and auto tire and parts
Oxfordbp
Jun 7, 2019 04:36 PM
Vinford
Jan 14, 2009 01:01 PM
vloney
6.4L Power Stroke Diesel
Jul 28, 2008 10:56 AM
LEIGUY
1978 - 1996 Big Bronco
May 11, 2004 09:36 PM
realdeahl
Feb 2, 2004 03:53 PM
