Lug Pattern and Wheel Question
Old Dec 2, 2003 | 02:02 PM
Samoan_Ridah's Avatar
Samoan_Ridah
I just traded in my '01 Expo for an '04 Expo and unfortunately my 20's don't fit anymore. I know that the original Expo had a lug pattern of 5x135. Does anyone know what the new pattern is? I know that it has 6 lugs but am not sure of the other number. Is it the same as the Chevy Suburban lug pattern?
TIA.
Old Dec 2, 2003 | 02:24 PM
Keydo's Avatar
Keydo
I believe it is 6 x 135mm
I've also seen 6 x 5.5 inches which works out to about 6 x 139mm
In any case, 135mm and 139mm isn't that far off.
Old Dec 2, 2003 | 05:54 PM
Samoan_Ridah
Thanks, if it is 6x5.5 then I think that is the same as the Chevy's. Now I just gotta figure out the offset and I'm off to the wheel shop.
Old Dec 3, 2003 | 01:26 AM
Monsta's Avatar
Monsta
Sit. Stay.
Why do I think the offset is 44mm.... Don't take my word for it but if when you find out let me know if I was close to being correct...
The lug pattern is indeed 6X135.
Old Dec 3, 2003 | 02:51 PM
Samoan_Ridah
Thanks Monsta, I will find out indeed. Oh, and thanks for confirming the lug pattern.
Old Dec 8, 2003 | 05:30 PM
kahunacanuck's Avatar
kahunacanuck
It is definetly not the same as the Chevy's. They went with an all new lug pattern for '03...the new F150 might be the sake. Check tirerack or discount tire for the exact numbers...
