Sponsored by: Real Truck
tire pressure ?
Old Mar 15, 2009 | 10:54 AM
BareBones's Avatar
BareBones
If you inflate your tires to the manufacturer's recommended pressure, then the only thing you have to worry about is center tread wear due to over inflation for the actual load you are running, whether in the front or rear.
What a lot of people do is scribe a white chalk line across the tires, drive a short distance (a block?), then read your tires. Repeat this with reduced air pressure until you get even wear on the tire.
If you want to be **** about it, you can even use white paint and go out on the interstate for a bit more realistic high speed reading.
Of course with a dually the tires will rub against each other if you go too low....
Old Mar 15, 2009 | 11:19 AM
Dually TAS's Avatar
Dually TAS
That at least sounds like something to try, I'll give it a shot since I just took out a mortgage on Michelins.
Old Mar 15, 2009 | 08:20 PM
jdboy's Avatar
jdboy
The chalk test is how I've ended up at the psi's that I mentioned above. The truck seems to ride well and the tread seems to wearing very even.
robert301972robert
1997 - 2003 F150
Apr 27, 2017 09:37 PM
Slade40
Mar 7, 2017 02:06 PM
prillium
Vehicles for Sale
Oct 19, 2016 10:05 AM
imcqueen
Colorado Chapter
Dec 1, 2015 02:22 PM
mykels
2015 - 2020 F150
Nov 18, 2015 02:28 PM
