E4OD Issues
Old Dec 22, 2024 | 01:46 PM
5.0Los's Avatar
5.0Los
6th Gear
E4OD Issues
Hey guys so I'm at my wits end here.
Truck is a 5.0 2wd with an e4od.
​When I put it in "D" the truck will automatically start in what seems to be 3rd gear. No matter what I do it will not go into 1st gear. Even if I manually put it in "1" it won't engage. I've gone down a rabbit hole of replacing parts and NOTHING has worked.
What has been done so far...
New mlps and tps
Tranny was rebuilt by a shop along with a new TQ
I cannot pull any codes, no matter what i try. I have the innova 3145 and it will not start the test it's supposed too.
Any help wohelp be HIGHLY appreciated.
Old Dec 22, 2024 | 04:12 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
When your trans doesn't have power, you'll have 2nd gear in both manual 1&2 positions and 4th gear in D position. Reverse will remain unhindered. You need to find out why no power is getting to the trans.
Old Dec 22, 2024 | 08:07 PM
1Butcher's Avatar
1Butcher
Why not ask your rebuilder?
Old Dec 23, 2024 | 07:21 AM
Scndsin's Avatar
Scndsin
Originally Posted by 5.0Los
I cannot pull any codes, no matter what i try. I have the innova 3145 and it will not start the test it's supposed too....
Remove computer, open & look for leaking capacitors.
Doesn't hurt to look at the PSOM as well.
Nothing like rebuilding a trans, throwing parts & it does the same damn thing.
Ask me how I know.
Old Dec 23, 2024 | 07:51 AM
JJF20's Avatar
JJF20
You need to post up the back story. What year truck?
When did the truck last run properly? New to you truck? Project? Long time owner?
Why was the trans rebuilt? Was this the original trans, or an exchange unit? What/which torque converter was used?
Was the original solenoid body reused or replaced - if so, which solenoid body was used? (‘94 and previous PCM’s can not be used with ‘95 and newer solenoid bodies.)
Who rebuilt the trans, and installed it?
Was the truck working properly before / when the trans was installed, or is this situation upon installing?
When were you last able to pull codes with your Innova? Ie, is this something new, or before the trans rebuild? Does the Innova power up, do anything, hooked up correctly?
Was anything else done when this happened? Why install a new TPS, TRS, etc - what led you to that? Previous Codes? Or just a Hail Mary? Is the TRS set up correctly?
Have you spoken with who ever rebuilt / installed the trans?
Old Dec 23, 2024 | 01:37 PM
5.0Los's Avatar
5.0Los
6th Gear
They only rebuild, they do not diagnose.
Old Dec 23, 2024 | 01:38 PM
5.0Los's Avatar
5.0Los
6th Gear
Ask me how I know.
I have removed it and it looked fine to me but then again I'm not too sure what im looking for. Ill post pics later today.
Old Dec 23, 2024 | 01:47 PM
5.0Los's Avatar
5.0Los
6th Gear
1) truck is a 91'
2)Truck is "new" to me, and has always ran the same since I acquired it.
3) OG tranny was rebuilt, i was very adamant to the shop on making sure the early style solenoid was used as im aware there was a change in the later years.
4) ill find out what tc was placed.
5) The Innova has never been able to pull codes, before nor after the transmission was installed.
6) local shop rebuilt it, I installed it.
7) ive replaced the mlps and tps just to eliminate those variables.
Old Dec 23, 2024 | 03:26 PM
My4Fordtrucks's Avatar
My4Fordtrucks
So who determined that the transmission needed to be rebuilt and what lead to that conclusion?
Old Dec 23, 2024 | 03:35 PM
5.0Los's Avatar
5.0Los
6th Gear
I decided to have it rebuilt thinking that would fix the problem.
Old Dec 23, 2024 | 03:42 PM
My4Fordtrucks
Expensive guess.
Old Dec 23, 2024 | 04:30 PM
Scndsin's Avatar
Scndsin
... I'm not too sure what im looking for. Ill post pics later today.
Do you know what a dead battery leaking looks like?
There should be 3 blue/black can like items with 3 legs on the board.
Corrosion leaks down the legs & onto the board.
Old Dec 23, 2024 | 04:58 PM
Dave 78 F250 460 2WD's Avatar
I see you said you replaced the TPS, but did you carry out the voltage checks first and after? This simple little part must be correctly adjusted after installation and it is very finicky.
Old Dec 23, 2024 | 07:04 PM
My4Fordtrucks
Nope. I install and move on with life. I might check the closed and WOT voltages but usually don’t. When I worked at the dealer we never adjusted them because there is no adjustment and according to what I’ve read the computer “relearns” the closed voltage every time the key is cycled.
Old Dec 23, 2024 | 08:52 PM
Mine is a late 90, 7.3IDI My year is not smart enough to 'learn' anything!! My TPS is fully adjustable and the shift points are very sensitive to even small changes in the voltages.
