P0446
Old Dec 21, 2024 | 05:25 PM
jwdenney2's Avatar
jwdenney2
P0446
2005 F150 4.6L 2wd automatic
Code P0446
*I have verified that the electrical connector is well seated in the solenoid.
*Voltage on the power wire (I believe red/yellow) is approximately 2.25 volts with key on engine off. As I was searching for a good ground, the voltage did jump up to around 12V momentarily, but I couldn't reproduce a 12V reading. I was able to get it to read ~2.25V twice (grounding in two different locations). So I'm a little leery of this, and I may need to run a ground wire to the battery and re-check the connector voltage.
*Continuity check passed on signal wire from solenoid connector to PCM C175b Pin 61 (approximately 65 ohms if I remember correctly)
*Resistance across solenoid terminals is approximately 68 ohms.
Can anyone tell me if the voltage reading is where it should be? If it is where it needs to be, does anyone know the next steps in diagnosing this code?
Thank you in advance for your help!
Old Dec 22, 2024 | 08:40 PM
projectSHO89's Avatar
projectSHO89
That's your failure. Should be full battery voltage with ignition in RUN.
Most likely, the conductor has either corroded or broken inside the insulation, usually within a foot or two of the connector for the CV solenoid.
Not uncommon.
Old Dec 23, 2024 | 10:22 PM
jwdenney2's Avatar
jwdenney2
The trouble turned out to be this connector in the harness against the outside of the frame under the driver's side door. It has given me trouble in the past, and I had previously cleaned it and added dielectric grease, but apparently the pins for this particular sensor had reached the point of physical failure. I jumpered around the connector and all is well.
f350project
Sep 14, 2014 04:35 PM
Aaron Hd Frazier
Jan 11, 2013 11:35 AM
jc-well
Oct 12, 2009 05:15 PM
snowmobiel0507
Electrical Systems/Wiring
Sep 26, 2005 04:22 PM
xuare
Apr 26, 2003 10:37 PM
