Wont start
Old Dec 20, 2024 | 04:26 PM
Ccrawford13's Avatar
Ccrawford13
7th Gear
Wont start
Good day all, i have an 86 e350 460cid.
i started it this morning, she was a bit cranky, but its really cold here. Warmed up just fine. Drove to a lunch place. Came out an hour later and all it did was crank, no sign of life. I went and got a can of start fluid, gave it a heavy shot, still cranked and cranked, not even a sputter. Leads me, with my limited knowledge, to believe theres no spark. Ive read the ignition modules are known to just go. Ive ordered a new one as well as a new coil. Am i on the scent or not? Any basic troubleshooting advice? I have a meter and know how to use it. Any advice appreciated.
Coil
Coil
Old Dec 20, 2024 | 08:46 PM
econo93's Avatar
econo93
Before ordering parts you would usually want to confirm there was no spark.
Tons of online info on how to do that:
https://www.aa1car.com/library/no_spark.htm
And:
https://www.google.com/search?q=chec...t=gws-wiz-serp
Old Dec 21, 2024 | 05:56 AM
manicmechanic007's Avatar
manicmechanic007
Highly likely it is the module
Sophisticated testing is involved with a no spark condition on a Duraspark ignition system
How the Ford dealer would diagnose it is with the Rotunds Breakerless Ignition Tester
I have one for the duraspark system I run on my Boss 302
Damn straight, those modules burn up, with absolutely no warning
The stators in the distributor just up and quit too
The testing is difficult without the special Ford tester box
You can get one of these testers cheap these days on Ebay (cheaper than the new coil you bought most likely)
Old Dec 30, 2024 | 08:44 AM
maples01's Avatar
maples01
You can test your coil with a multimeter, look it up on youtube, they leak out oil in time as they are mounted laying down, when hot they quit working.
St.Michael
Nov 26, 2023 05:50 PM
dylansf23
30
Nov 30, 2013 07:38 PM
eagleno49
Jan 23, 2010 03:51 PM
