Sponsored by: Real Truck
Very weird Ipr problem/electrical problem??
Old Dec 17, 2024 | 11:01 PM
Haze6.0walsh's Avatar
Haze6.0walsh
1st Gear
Ipr electrical issue
2003 6.0 power stroke I’m about to burn this truck down so I am having a high-pressure oil problem and I am only building around 480 psi of pressure. I have a brand new Hpop in it J tube all Ford OEM O-rings, new standpipe O-rings and oil rail o rings and all that sort of stuff pressure tested the oil system and everything checks out no leaks whatsoever. I had a cheap ipr valve in there so I thought that was a problem and pulled that out and went and got a new Ford OEM one put that in still the same thing if I command the IPR valve shut with 12 V from the battery for a few seconds to oil pressure jumps right up to 2800 psi but if I have it hooked up to the harness, it doesn’t close all the way for whatever reason even commanding it with forscan it’ll open up all the way and close 1/2 of the way, but not fully. I did the air test on it too and the same thing. Long story short I am led to believe it is a electrical problem. It has an all new wiring harness in it and everything has anybody ever had this happen before I’m thinking it might be a bad PCM. Any help is greatly appreciated Thanks Hazen
Old Dec 18, 2024 | 07:53 PM
Baylinerchuck's Avatar
Baylinerchuck
Grab a good scan tool like ForScan and head over to the 6.0 section of the forum. Be prepared to share some data. See ya there.
036.0stroke
Jan 14, 2023 05:42 PM
mtbnski
Nov 10, 2014 08:16 PM
DItR
Aug 22, 2013 10:37 AM
pbjlamar
Mar 11, 2013 01:37 PM
wmjoe1953
Sep 26, 2008 08:03 AM
