P0305/PCM question
Old Dec 17, 2024 | 09:50 AM
colorado_junkie's Avatar
colorado_junkie
P0305/PCM question
Good morning everyone. I started my 2011 3.5L Ecoboost this morning and the CEL came on instantly. After letting the truck warm up a minute or two I started to drive over to O'Reilly's to have the code read. Right away I can feel something was wrong and the CEL started blinking. The engine code was P0305, which I am no stranger to. Now, my question is....when the O'Reilly's report says Permanent (taken with a grain of salt) does that mean the PCM is bad and needs replaced or can the codes be cleared by Ford and keep the PCM? Reason I ask is I recently had a 2008 Ford Taurus that had this exact same issue and the local Ford dealership gave me an expensive run around, telling me the PCM was bad and needed replaced. Thanks in advance for any thoughts/suggestions.
Old Dec 17, 2024 | 11:15 AM
RLXXI's Avatar
RLXXI
That code is cylinder 5 misfire. Had nothing to do with the pcm. Permanent code just means the pcm had to clear the code on its own once it sees the misfire fixed. Could be coil, plug, injector base engine. Need to run some diag on it to be sure.
Old Dec 17, 2024 | 11:50 AM
colorado_junkie
So, theoretically, if I change coil, plug and/or injector and the CEL stays on with the same code would that determine the PCM to be bad? Just looking forward to my next steps if needed. I'm a desk jockey so I can't get to the truck till this evening. My plugs and coil packs are at ~30,000 miles right now so I'm a bit surprised to see this code.
Old Dec 17, 2024 | 01:53 PM
RLXXI's Avatar
RLXXI
I don't deal in hypotheticals or theories, I deal with cold hard facts and the only way to get them is to put hands on and diag the machine. Could also be critter damage, rats/squirrels like to make nests around a warm engine in the winter and love to gnaw on wiring.
Give it a good look over, may need a borescope to get eyes on some of the harness under the intake manifold. If you don't see any physical damage then it's time to get deep into diag and that requires special tools/equipment/knowledge. Forced induction engines are notoriously hard on everything especially spark plugs. 30k miles is not unheard of for a plug to go bad on that engine.
Also if you used anything other than Motorcraft/Ford plugs/coils, you likely found the problem.
RenoHuskerDu
Oct 15, 2020 03:47 PM
rolltide3006
20
Jun 24, 2013 09:01 PM
noplugs
Apr 8, 2011 09:04 AM
modru2004
Computer Chips & Tuners
Apr 13, 2004 07:31 AM
