Glow Plug Clicking
Old Dec 16, 2024 | 08:40 PM
Rutherford_813's Avatar
Rutherford_813
4wd Low
Glow Plug Clicking
Hello Everyone, I’m hoping someone could point me in the right direction so yesterday I was turning the fuel up on my 1990 7.3 idi and I was doing it by my self and was jumping the starter relay to turn the engine over in order for the Allen key to lineup. After I was done, I went to start the truck and noticed that I now had a nonstop clicking from the glow plug relay. The wait to start light would come on literally less than a second and the clicking would start and it’s nonstop. Does that mean that the whole glow plug controller is shorted out or could it be something else? I did try swap the relay out on the controller and it still clicks non stop, the fuse in the cab is also still good. And like I said it was not doing this until I messed with the fuel and I don’t know if I shorted it out by jumping the starter relay, but I’m hoping somebody could point me in the right direction thank you in advance.
Old Dec 17, 2024 | 01:02 AM
ihc1470's Avatar
ihc1470
Quick easy test, clamp an inductive ampmeter around both of the wires on the solenoid on the controller the wires that feed out to the glow plugs. Pull the white wire off the solenoid and with key on ground the terminal for a few seconds. Get your reading. You should see close to 200 amp draw maybe a little more if all is working well. If you do not see that then test one wire and then the other to determind which bank has the issue. Maybe they both do, would not be all that unusual.
You did not by chance pinch a wire while work on the pump.
Old Dec 17, 2024 | 07:06 PM
Rutherford_813
4wd Low
Thanks for replying, I just ended up bypassing the relay and putting it on a push button and the clicking stopped, it only clicks on when engaging the button and truck starts fine. But now the battery light is on and will not turn off, I did swap the alternator out for a 3g a couple of years ago and I did check that, it’s getting 14.7v while running and 12.7v while engine is off and the battery’s are at 12.5v while off and up to 14.5v while running. I don’t know if bypassing it made the light come on someway but it won’t turn off, I did also pull both positive cables off the battery’s while running and the truck did not turn off, I let it run like that for a few minutes before hooking them back up. Any thoughts on why the lights on now?
Old Dec 18, 2024 | 04:51 AM
tjc transport's Avatar
tjc transport
i ain't rite
pull the glow plug relay bypass and see if the battery light goes off.
disconnecting batteries on running engine with alternator is not healthy for the alternator.
that was a trick from 60+ years ago to see if a generator was charging.
but doing it to an alternator can cause it to go full voltage and damage the alternator because it need to see a load for the voltage regulator to work.
Old Dec 18, 2024 | 04:26 PM
Rutherford_813
4wd Low
Okay, I'll give that a go, do i pull the bypass wire after its running?
Old Dec 18, 2024 | 04:27 PM
Rutherford_813
4wd Low
Okay I'll give that a go, do I pull the bypass while the vehicle is running?
Old Dec 18, 2024 | 06:43 PM
tjc transport
i ain't rite
yes.........
Old Dec 19, 2024 | 03:06 PM
Rutherford_813
4wd Low
yes.........
So I pulled the bypass off while running and battery light proceeded to stay on. Any more thoughts?
Old Dec 19, 2024 | 05:45 PM
Rutherford_813
4wd Low
yes.........
so after pulling and no change I decided to check the glow plug connectors. I put one plug of the multimeter on the stud that goes to the glow plug harness and the other and in each one of the connectors check and checking them, I was getting .5 ohms on the driver side and .0 OHMS on the passenger side does that mean the harness is fried or there’s a break in it somewhere and would that make the battery light come on?
Old Dec 19, 2024 | 05:57 PM
tjc transport
i ain't rite
no. the battery light is on because either the alternator is not charging, or the voltage regulator is bad.
with engine running check voltage at batteries. then check voltage at large terminal on back of alternator.
battery voltage engine running should be somewhere between 3 and 13.5 volt. voltage out of alternator should be 14 or so.
Old Dec 19, 2024 | 06:09 PM
Rutherford_813
4wd Low
I did swap the alternator out for a 3g a couple of years ago and I did check that, it’s getting 14.7v while running and 12.7v while engine is off and the battery’s are at 12.5v while off and up to 14.5v while running but I’ll double check the batteries again here in a few just to confirm.
mcali2
38
Sep 22, 2018 04:27 PM
kawasakiklx1
Feb 23, 2018 04:35 PM
jonathanpatr
Oct 20, 2014 05:54 AM
ineedhelp92
Feb 11, 2013 09:50 PM
moosebrew
18
Aug 30, 2012 07:49 PM
