2024 Flatbed install
Old Dec 16, 2024 | 06:05 PM
Justin Hilltop's Avatar
Justin Hilltop
2nd Gear
I just purchased a 2024 F-350 super duty. Laramie Trim package. Having a custom flatbed installed on it. Everyone I've talked to says I'm going to lose my 360 view. Is this true? If so are there any aftermarket kits I can install?
Old Dec 16, 2024 | 08:49 PM
1olddogtwo's Avatar
1olddogtwo
The 24, you should be ok I believe. The problem was with the 23 model. With the 24, you'll have At least 270°
You may have other issues depending on trim and packages on the truck. A good installer should have work arounds.
I have quite a few flat beds, but they are chassis cabs.
Does your truck have the integration package on the sticker? And you must be coming from Ram to Ford, cuz Ford doesn't offer a Laramie package.
Old Dec 17, 2024 | 01:48 AM
406f150's Avatar
406f150
This is posted on the Bradford Built website. Dated 2022 so not sure if anything has changed now.
Old Dec 17, 2024 | 09:25 AM
Justin Hilltop
2nd Gear
Yes my last truck was a Ram 3500, Lariat trim. Checking integration package now.
Old Dec 17, 2024 | 12:09 PM
Doug72highboy's Avatar
Doug72highboy
If you add the compatible camera to the back of the flat deck, as close to the same position as the tailgate camera, it is possible to re calibrate the system (not sure how, maybe forscan). The image will never be perfect, but better than no cameras.
The camera system is really picky about which camera is used. Also lots of people have issues just removing the tailgate with the tailgate ajar code staying up. Not sure if this was resolved, but ford has made it much trickier to flat deck a pickup. Chassis cabs are much simpler to work with.
dannko
Jan 11, 2019 12:50 PM
ChiefGeek
Feb 18, 2018 06:02 PM
Larry NCKS
Apr 3, 2011 03:29 PM
Badger F350
Feb 16, 2010 11:53 AM
OBX Powerstroke
Sep 7, 2009 07:59 AM
