Lift pump recommendations
Old Dec 20, 2024 | 08:02 AM
tjc transport's Avatar
tjc transport
i ain't rite
sure do know that hill Matt.
WCM, i think you have other issues, lime mayby a restricted fuel line between tank and pump.
as Matt said, i too have done some hard pulling with the fuel pump off and only realized it when the fuel filter restriction light came on. flip the pump switch and light goes out.
the switch gets hit because it is in a bad spot. i have it wired to a fused switched power source in cab so the pump only runs when key is on, but have the switch to turn pump power off if i am doing something where need key on engine off.
every time it gets accidently turned off i say im going to move it, and then forget to by the time i get home.
Old Dec 20, 2024 | 08:31 AM
WCMtn1990's Avatar
WCMtn1990
Originally Posted by mattnj
I often load 2 tons of stone, come to the traffic light exiting the supply yard and then need to climb a steep hill right across the road, not a long stretch, about 500 feet or so. By the time I am at the top I am in 3rg gear and never seen the engine starving for fuel. Tom should know the place (J. Manzo on Rt34 and Reids Hill Rd). Never measured the pressure as I have never seen a problem with mine.
One interesting thing I noticed. I have an independent switch for the pump and once drove at least 5 miles until I realized that the pump was off, and engine seemed to be happy... odd.
I run the pump from a switch with key-on power and have accidentally turned it off and not realized until I started up a hill and the filter light would illuminate. My measurement of 5psi at idle with the 9-11psi Dura-Lift is on par with what many others have measured at the same point, and they also found the pressure dropped quickly with a little throttle and at WOT would hit 0 psi easily. I wonder if there have been better and worse batches of these pump over the years. I get the same psi readings at idle regardless of which tank the pump is pulling from. Again, there seem to be plenty of folks that claim to not have a problem and there are plenty of folks, very competent folks, who find the pump can't flow enough fuel for an N/A or stock turbo setup. I drive a 10% grade almost everyday and the pump does a fine job up until about 2500 RPM but it just can't keep up beyond that for very long. I do have a new vacuum sensor on order because I have wondered if mine was properly functioning.
Old Dec 30, 2024 | 11:44 PM
DCarrVan's Avatar
DCarrVan
Originally Posted by Prototypemech
You're local international dealership can get you a OEM lift pump for about $150 that'll last 20 years.
Still ? An off Question....but my 93 7.3 i should change Glow Plugs How Many Years ? ....and is there anywhere to Get a Relay that Lasts ? Love to Have a Direct Switch By Bass Hooked up by a Good Auto sparky
Old Dec 31, 2024 | 02:18 PM
tecgod13's Avatar
tecgod13
There is no set lifetime for glow plugs, replace them when they fail. Only use genuine motorcraft/beru glow plugs, all others tend to fail rapidly, and sometimes catastrophically.
There are good directions on here somewhere on how to wire up a manual glow plug switch, might be up in the stickies, I can't remember.
Old Dec 31, 2024 | 03:50 PM
tjc transport
i ain't rite
glow plugs get changed when they start dying. i average around 150-160,000 miles out of glow plugs.
the last glow plug relay i changed was around 20-25 years ago, and i put a stancor in as i was tired of the small ones dying every 3-4 years
6.9Lardass
33
Sep 23, 2021 10:06 PM
Jimv8
Aug 24, 2021 03:38 PM
MtTheJeffro
Jul 13, 2016 06:33 AM
'94IDITurbo7.3
Jan 6, 2012 04:42 PM
