if it’s cold weather….would recommend anti-gel and lube additive …reduced fuel flow could indicate as more cp4 noise
its 24 degrees this morning and I’m running a double dose of opti lube winter and have fresh pure synthetic 5w40. I expect the motor to sound very rattle type noisy at startup.
does cold weather effect these engines outside of startup, ie idling in the drive after driving 30 minutes
