Replacement panel?
Old Dec 12, 2024 | 05:48 PM
Itsasixty5's Avatar
Itsasixty5
Replacement panel?
1965 F100.
Does anyone know if a replacement panel or patch is made for the cab panel behind where the front of the door and fender meet.
I have a pic of each side of mine where its bad, pardon the orientation, the cab is currently sitting vertical on the frame so I can work the underside.
Old Dec 12, 2024 | 05:59 PM
52 Merc's Avatar
52 Merc
Is that little hole the only bad spot, or is it worse than it looks. That small repair could easily be made by hammering a piece of sheet metal around and made to fit pretty easy, and save a lot of money buying an ill-fitting, off shore made replacement.
Old Dec 12, 2024 | 06:24 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Here are some US made panels.
https://carolina-classics.com/collec...1tz-8102055-pr
Old Dec 12, 2024 | 06:34 PM
Itsasixty5's Avatar
Itsasixty5
Yes on both sides, I assume its where the cowl drains out.
I was just curious before I went the hammer and steel panel route.
Thought I was going to have to replace the floor pans too, but there's only a few spots on each side that a 2 inch strip about 9 inches long will fix.
Itsasixty5's Avatar
Itsasixty5
Thanks for the info - Holy crap 160 a piece - I think I will try the hammer and steel route first.
Bluey Zedoff
Sep 22, 2024 04:28 AM
Truckerbase
16
Jun 7, 2024 10:10 PM
Jairus7.3
Jun 6, 2023 09:35 AM
Bluey Zedoff
Feb 25, 2023 06:02 AM
newguy399
Dec 20, 2015 03:16 PM
