Heat Issue
Old Dec 11, 2024 | 06:47 PM
Croos Country's Avatar
Croos Country
1st Gear
Heat Issue
Sorry for revisiting the wheel, but I am figuring out how to navigate this site.
Have heat issue? 2006 F250 6.0
Problem is no heat unless under load? Idle there is nothing but cold air coming from system?
What ive done?
^Changed out T-stat.
^Changed out heater control valve.
^Soaked and flushed heater core and reversed flush as well. (Water flow both directions no problem)
^Filled with coolant and ran truck for 45 min with defrost on high. Heat was working until home at idle. Turned off truck and snatched new degas cap off fast and herd air come out of system.
^ Inlet hose to core is hot, but return to degas is not?
^Coolant is between 178-190 after warmed. per tuner.
^I'm with in 6-7* on my gauges.
With that said, I'm wondering if there is more air trapped in the Heater core?
Can water flow through the heater core when flushing and bypass the clog showing as unclogged with nice flow?
Thank you for any feed back!
Old Dec 12, 2024 | 04:28 AM
Baylinerchuck's Avatar
Baylinerchuck
Sounds like the valve that works off vacuum at the firewall either has no vacuum to open, (disconnected tube, or control issue), or is faulty. I think you can manually actuate this to ensure it’s not stuck.
Old Dec 13, 2024 | 02:42 PM
FiveOJester's Avatar
FiveOJester
Like chuck said make sure the heater valve is opening. I believe it defaults to open, you have to wire it shut so likely not the issue unless it was assembled backwards.
Otherwise check the blend door actuator. Take out the glovebox and it's right there. You should be able to see it move back and forth when you adjust the temp dial.
Tyrone_White
1997 - 2003 F150
21
Dec 8, 2019 09:03 AM
tweak1029
Mar 28, 2016 02:27 PM
granny_rocket
Jan 20, 2015 06:48 AM
BassMan 32
1997 - 2003 F150
Jan 20, 2005 12:29 AM
77'F-150Mudder
17
Dec 7, 2003 02:18 AM
