Lots of short drives? With mostly local errands all of my vehicles need additional charge help with all the things sucking down battery while parked these days. Probably once a month I throw an external charger on overnight.
Some short drives, but even on longer drives same thing.
Mine will sit sometimes 1-2 weeks at a time. It seems to be in battery saver mode quite a bit. I noticed yesterday, the battery looks to be sulfating on the top around the water caps. I had to disconnect the battery for 10-15 minutes to get the door handle lock/unlock to work again for the umpteenth time. The manual states that the negative terminal should be disconnected if not going to be used for a while. I guess it’s time to get a trickle charger. Ridiculous.
Pull both batteries and deep charge them with a sulphation(sp?) charger. With all the keep alives on these trucks, they will wear a battery down, especially those that have not had a deep charge cycle like an 8 hour interstate run will give them.
