Update Forscan, you are using 2.3.19 the latest is 2.3.63!
Updated it shortly after. Going to give that a go here shortly. Hopefully that does the trick.
Edit: updated to latest version of Forscan and it worked. Was able to make the changes to the BMS and let the system know charge profiles were for AGMs.
