Looking at gooseneck trailers
Old Dec 1, 2024 | 07:30 AM
nickm347's Avatar
nickm347
4wd Low
I'm looking to get a Gooseneck trailer, something as small as possible for maneuverability reasons. The biggest thing I will likely tow is a crew cab dually (Ford F-450 pickup, for example).
I've been looking at the Big Tex 14GN. Will a 20 + 5 work or should I go bigger?
Old Dec 1, 2024 | 09:16 AM
meborder's Avatar
meborder
My experience with trailers is that until you hit the physical limits of:
1- your tow vehicle
2- your intestinal fortitude
there will always be a time where you wish you had a bigger trailer or more weight carrying capacity.
Old Dec 1, 2024 | 09:49 AM
BadDogPSD's Avatar
BadDogPSD
Kinda difficult to answer when we don't know the purpose of the trailer. What do you plan to haul with it?
** edit, I read the post as towing WITH a 450 **
Old Dec 2, 2024 | 01:13 PM
jcb804's Avatar
jcb804
A 20' + 5' is not going to leave any room to balance your max projected load of crew cab F450. You're going to be stuck nose heavy or tail heavy on the trailer. Either one will put you in a ditch real quick.
Old Dec 2, 2024 | 03:13 PM
ATC_F350's Avatar
ATC_F350
I've hauled an '01 F350 SB on my 20+5 and it pulled great. The only problem was there was just enough room to fold the ramps up with the truck on it. I did have a Ranchhand bumper which pushed it back a bit. With the ramps folded, you can roll the truck back and forth if necessary to balance it out.
Old Dec 2, 2024 | 06:23 PM
jcb804's Avatar
jcb804
Yeah, a crew cab F450 pickup is close to if not more than 22' long. Ive moved more than a few 450s and 550s on a 25ft tag trailer attached to an F650. It didnt matter that the truck was parked nose forward on the trailer with an F650 but it sure will hooked to a pickup truck. Even if you spin it around there will be too much weight over the axles to the rear of the trailer turning it into a wagging tail.
Old Dec 14, 2024 | 10:45 AM
scottz99's Avatar
scottz99
Veteran: Navy
I am also looking for a GN. It seems you guys think a 20 + 5 is not enough. So, what length do you recommend for trailering a large pickup behind a F-450?
Old Dec 15, 2024 | 06:30 AM
GetMore's Avatar
GetMore
There are a number of variables relating to the load.
How long will that truck be?
Diesel or gas?
Pickup bed, utility body, flatbed, nothing on back
Will it have anything in the bed?
What will be on the front? Plow, winch bumper, stock?
Will there be anything hanging off the back?
Will you need to carry anything on the deck with the truck.
Basically, you need to have room to balance the load on the trailer, so about 15% of the loaded trailer's weight is on the tow vehicle. This means you'll need room to move the load, to find the balance.
As mentioned above, it can be very useful having room to pull the vehicle onto the trailer and fold the ramps onto the deck, so you can then move the truck back, over the ramps, and get the right balance.
My recommendation is to determine your worst case scenario, and work from there. Most likely someone here has done it and can let you know how it went or whether they may have wished for a different trailer and why.
Old Dec 16, 2024 | 10:09 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
We need more information. For example: Your profile says you drive a 2000 Explorer:
For example: Does your Explorer have a V-6 or a V-8? Makes a difference when we talk about towing.
But seriously: Are you towing with an F-250 or a F-550 or a Chevy 1500 or a Nisan Titan or . . . ?
If I guess that you are towing with an F-350 DRW, I'd also guess that something with a 25-foot deck and no folding ramps would be okay.
If I guess that you are towing with an F-250, I'd also guess that something with a 30-foot deck and no folding ramps would be okay, as this would allow you to adjust the tongue weight a little more since you'll probably need to with an F-250.
If I guess that you are towing with a Chevy 1500, I'd advise against trying this, and probably cause someone to lecture me on being the weight police while telling you to just send it. LOL
Also, is the F-450 a bare cab and chassis, or does it have a utility bed or motorhome box or some other thing on it?
Douglas V
All Things Towing
15
Feb 1, 2024 04:01 PM
digz
2021+ F150
Sep 16, 2021 07:14 PM
OldWoodsDiesel
24
Jun 11, 2013 11:23 AM
HAMMERDOWN103
Jan 24, 2013 05:13 AM
snooziums
Mar 14, 2005 06:11 AM
