300 EFI Missing After Running A While
Old Nov 28, 2024 | 06:40 AM
Jeffalex2's Avatar
Jeffalex2
4th Gear
I have a recently acquired 89 F150, 5 speed, 4.9 (300) EFI. Love the truck! I usually just drive it around town but recently took about a 1 hour trip and noticed that after a while, she is missing on at least one cylinder. It's totally fine on cold start and 15-20 minute drives. But after a while, there's a miss.
Work I've done on it: removed EGR and CAT, new 02 sensor, new temp sensors, new fuel press reg, new distributor (old coil? maybe problem?)
I'm going to get a fuel pressure gauge and check that out.
Anyone have any other thoughts? Thanks!!
Old Nov 28, 2024 | 08:27 AM
jas88's Avatar
jas88
Once it is warmed up and missing, pull your plug wires one by one and see if you can isolate it to one cylinder.
Old Nov 28, 2024 | 10:12 PM
Prototypemech's Avatar
Prototypemech
Remove your ICM from your distributer, clean the mating surfaces to remove any old grease. Slather the back of the ICM with real heat sink compound (not dielectric grease), and reinstall. You can get heat sink compound from Amazon for CPUs. The fancy stuff has nano diamonds.
Magnaman8812
Dec 3, 2023 11:09 AM
Samsn4
Ford Truck Parts for Sale
May 30, 2015 10:02 PM
cowboy.2010
Apr 23, 2014 11:05 PM
rentakid94
Nov 28, 2012 11:31 AM
old'skewl
Jan 27, 2011 08:44 AM
