Sponsored by: Real Truck
Shock recommendations
Old Nov 27, 2024 | 07:47 AM
smr camper's Avatar
smr camper
Hi need new shocks.
we tow a 16k 5th wheel and then it's our daily driver. Don't go off road.
I usually just go with what is original to the vehicle which are Rancho shocks.
Not sure if there is a better shock for a smoother (lol) ride and can handle the 5th wheel.
Thanks
Old Nov 27, 2024 | 10:45 AM
Tungtide's Avatar
Tungtide
4wd High
Opinions on this subject are numerous. I just did my shocks on F-350. Went with Rancho 5000 on front and Nappa on rear. Much to be said about KYB’s have those on my off road van, Bilstein are loved by those who own them. ( to pricy for me ) best wishes.
Old Nov 29, 2024 | 01:25 AM
INFRNL's Avatar
INFRNL
Fox or Bilstein would be my choice, not a fan of rancho...I will say any shock is better than a bad shock though. Depends on if you are looking for something specific in performance. I've run gabriel in the past and they were a good softer ride with good control, but this allows for more body roll even with the anti sway bars. If a person wants cheap shocks, you typically get what you pay for and while they might be okay, they typically don't last from my experience.
If you were happy with the original shocks, stick with rancho. At least you will know what you are getting and it won't be a gamble.
Old Nov 29, 2024 | 09:00 AM
speedfreak78's Avatar
speedfreak78
This right here. I've always recommended "higher end" parts to anyone that's asked my opinion, then get shut down immediately because of cost. And I'm not talking performance high end stuff, just the better brands of replacement parts or OEM/factory parts. Then they buy the cheap stuff and wonder why it doesn't perform as well or last as long the original they replaced.
I've had everything from $10 parts store specials to $300+ bypass shocks over the years over many different vehicle and the truth is, generally, the more you spend on shocks, the better ride quality, handling and life you're gonna get out of them. And once you start getting into the higher end aftermarket shocks, even though they are usually much more expensive up front, they can be tuned for your specific vehicle/use and rebuilt for a fraction of the cost in the future.
Old Dec 3, 2024 | 11:02 PM
droldsmorland's Avatar
droldsmorland
Rancho 9000 adjustable. Worth every penny.
Truck rides like a different truck, like a 150.
The auditability adaptability is nice to dial in the ride. I have mine set on 2-3 out of 10 for daily. If I'm hunting/towing I bump them up to 5. 4 wheeling 1.
If you go with these pull the adjusting ***** off and pack the cavity with high end synthetic grease. If you don't they will seize up if you live in the rust belt or regularly wheel through water.
Old Dec 4, 2024 | 08:28 AM
Charlie98's Avatar
Charlie98
The auditability is nice to dial in the ride. I have mine set on 2-3 out of 10 for daily. If I'm hunting/towing I bump them up to 5. 4 wheeling 1.
Rancho 9000's were what I was going to suggest as well. I had those on my 1999 F-250, and it was nice to be able to dial in the rears for the load I was carrying.
I put Bilstein 4600's on my 2009 F-250, but they didn't help the underlying issue of a too-soft suspension, otherwise, I think they are good shocks. I plan on putting Bilstein 5100's on my 2023 (4x4) and very likely another set of 4600's on my soon-to-be-built 2025 (4x2.)
I kind of got away from Rancho because of the poor build quality, however. The past few sets were pretty sloppily built, and one of the RS5000's I put on my 2017 2500HD was undervalved from the factory.
Old Dec 4, 2024 | 10:42 PM
PROSTOCK's Avatar
PROSTOCK
I have 9000's on my '12 KR and never again. Helped a little towing, but too little rebound damping, could never get great results. PITA to adjust too.
Bilstein 5100 or Fox 2.0.
Put 5100's (variable lift frt) on the daughter's '07 F150CC and am blown away. When I can scrape together $800, I'll get Fox for my truck.
Old Dec 6, 2024 | 12:48 AM
INFRNL's Avatar
INFRNL
haha...they still make the rancho adjustable shocks. I ran those 25 yrs ago or so. thought they were cool; nice idea, but they didn't last and performance was meh...maybe they've made improvements since then.
It may have been mentioned but most shocks are just a generic shock and not properly valved for our trucks...just saying. You don't run the original canned tunes do you
whatever floats your boat(no pun intended).
i have Fox remote res shocks up front that are supposed to be valved for my truck and same series non res fox in the rear. But most don't want to spend that extra money as has been mentioned. My shocks will hold up better and can be rebuilt.
my buddy loves rough country 2.0's but he's always replacing them
Old Dec 6, 2024 | 05:40 AM
2015 F-350's Avatar
2015 F-350
Strange. I went to Bilstein's site and they recommend 4600 for a 2015 Ford F-250 and not a 5100?
Old Dec 6, 2024 | 03:34 PM
speedfreak78
Pretty sure the 4600s are a stock replacement and the 5100's are for leveled trucks. At least that's how it was on the older stuff.
Old Dec 6, 2024 | 03:52 PM
Diamnd1's Avatar
Diamnd1
I have had Bilsteins on every truck I have had for 25+ years. I currently have 5100's on my SD. Never had any issues or problems with them at all. 4600's if you mostly use your truck on weekends, 5100's if you tow or work the truck. 4600's give a softer ride, 5100's are more stiff with good rebound dampening. JMHO.
Old Dec 6, 2024 | 08:03 PM
Blue Haze 1's Avatar
Blue Haze 1
1st Gear
bistien shocks 5100 they you will not go wrong.
Old Mar 25, 2025 | 07:28 PM
smr camper's Avatar
smr camper
Finally got time to replace the shocks.... I went with 4600's per Bilsteins recommendation, as mentioned above the 5100 are for lifted trucks.
The Ranchos were bad, what a difference
thanks for the info
Old Mar 27, 2025 | 04:56 PM
70XLT's Avatar
70XLT
I installed the same on my 2013 PSD (stock suspension) a couple years ago on all 4 corners. About 20K miles later they are still performing great. You made a good choice.
acdii
Sep 30, 2023 06:34 PM
sscarboro
Feb 13, 2015 01:26 PM
MIKES 68 F100
15
Aug 27, 2012 03:17 PM
RangerHaywood
Jun 22, 2010 06:41 AM
boogerbutt
Jul 21, 2004 05:29 PM
