Sponsored by: Real Truck
No 4wd
Old Nov 25, 2024 | 02:44 PM
Lapjustin's Avatar
Lapjustin
2nd Gear
No 4wd
Have a 2014 f250 has the 6.2 in it. Lock hubs in switch **** to 4wd can hear a click but front tires dont turn. Checked the hubs were working both axles locked when i lock hubs in. Could be actuator problem? Unfamiliar with how these work
Old Nov 25, 2024 | 07:43 PM
Overkill2's Avatar
Overkill2
If you have 4wd when you manually lock the hubs but not in auto mode, then you have a vacuum problem somewhere. Not sure where, could be leak in one of the vacuum lines to the hubs, one of the hubs could have a leak internally as they use vacuum to pull in the hub into locking position or the vacuum pump in front of the engine... IIRC the vacuum line block is behind the primary coolant tank on drivers side... again, I could be wrong.
The fact that you heayou click makes me think the vacuum is working but the hub is having a problem locking in...
Old Nov 26, 2024 | 08:39 AM
Lapjustin's Avatar
Lapjustin
2nd Gear
[QUOTE=Overkill2;21413046]If you have 4wd when you manually lock the hubs but not in auto mode, then you have a vacuum problem somewhere. Not sure where, could be leak in one of the vacuum lines to the hubs, one of the hubs could have a leak internally as they use vacuum to pull in the hub into locking position or the vacuum pump in front of the engine... IIRC the vacuum line block is behind the primary coolant tank on drivers side... again, I could be wrong.
thats the thibg when i lock them in it still dont spin the front once i lock them i reach behind tire i can grab axle and feel its locked. Its the the turn **** on the dash isnt activating anything in transfer case. It clicks when i turn but nothing else
Old Nov 27, 2024 | 10:31 PM
Overkill2's Avatar
Overkill2
Okay... so it sounds like you may have an electrical problem, because if you had a vacuum issue, you would still have 4wd when you locked the hubs in... so digging deeper for you, I found this:
https://www.powerstroke.org/threads/...ution.1381522/
Our trucks have a transfer case control module... hopefully this will help and I just learned this myself...
254XP3
Dec 13, 2017 08:14 AM
frkncrazy
1983 - 2012 Ranger & B-Series
Oct 2, 2016 12:52 PM
Rongold
Nov 24, 2015 08:24 PM
ddwood55
Jul 8, 2015 09:07 AM
DJMORETON
Jan 11, 2011 08:36 AM
