Wiring Help
My diagram does not show the blower switch or blower as if this was an option on this truck.
I can put a hot on the blower and it works fine but not when I hook up the switch....SOMEONE HELP MAKE MY TEETH STOP CHATTERING PLEASE by sending me a diagram if possible.
Wayne S.
Maybe try bypassing the switch it could be dirty/corroded/pitted/worn out.
p.s. was it only the 68 with the round **** controls and then the slide type from 68-72 ?
If it's a fuse box fault, knowing my lazy rear, I'd just run a new wire to the fan switch from the battery, or other good high current power source, and use an inline fuse. Not the most elegant fix, but about 500% easier...
It wouldn't be anything really noticable to the average viewer... The wires would still be hidden. MK
mike
Thank you all for your input on this
Wayne S.
Wayne S.
I would still love to get my hands on a decent wiring diagram for future problems.
Wayne S.
Since most of my temporary fixs end up semi-permanent, I don't reccomend running a wire to the battery for anything. Since the fuse block in these old trucks is woefully inadequate, I would get a good aftermarket fuse block and get one that has a dual feed capability. Run at least a 12 guage(10 would be better) wire from the starter relay hot to one side and use a relay through a key on power source for the other side. Now you have a place to run acessories and reroute other things through.
IE: any connector will plug into any other connector, and you can't go the wrong way by accident. The contacts are silver plated and rated for 50 amps at 600v.
Back when I usually drove a monte carlo, I kept a second battery behind the back seat for radio use only. All my wiring and connectors are so heavy duty I can actually jump start the car from the 2nd battery without even opening the hood, or getting out of the car. I just unhook the radio, and plug it's power cable into the one from the 2nd battery. And the wiring and connector won't even get warm.
I keep a spot for a 2nd battery in the back utility bed box of the truck.But I agree, for just a fan fix, I'd prefer to keep the wiring in the cab. But being lazy still, I'd probably just run a short clip jumper from the fan side of the fuse on the fusebox over to the fan wire. Bypassing the bad spot on the back of the box. I bet that fuse box is a pain to change out being you have to do it nearly standing on your head or crunched next to the truck in a near fetal position.
Not much room to work either. I dread the thought of changing mine...Doesn't look like fun. Maybe it's easier than it looks...Plumcrazy, As far as the possible crimp, one way to test would be to run a short jumper wire wrapped around sharp pins on each end to stick thru the insulation into the wire and bridge the possible bad spot. That way if it's not the bad spot, nothing is damaged with the wiring. If the fan comes to life, thats the bad spot. But, dunno...I've still got a hunch it's a flaky connection on the back of the fuse box. Mainly cuz I had the same exact thing happen with my cig lighter circuit. I never did really fix it properly. I just jiggled the wire and fuse box until it started working again, and I no longer use my cig lighter much. The dome light doesn't draw enough current to be a problem, only the lighter in my case. I've been thinking about running a fairly high current wire to the lighter, so I can run fairly high current gadgets off of it if needed. IE: laptops, inverters, chargers, etc. To me and my way of thinking, if a wire was hanging by a thread, and then you start the fan and draw a large load, the thread of wire should burn up. That it's intermittant, to me, points to a flaky connection on the fuse box. That won't instantly burn up like a wire. It just gets hot for a second at that point, and gets slightly more resistive due to the arcing and overheating. It's like trying to start a car with the battery cables just laying on top of the posts and not tightened down. Sure, the dome light might work. Until you try to crank the engine, and all goes deader than a doornail...
MK
