Shock Dilemma
Old Feb 6, 2025 | 05:32 AM
  #31
Darko Marko's Avatar
Darko Marko
Sounds like your front spring rate is the issue. What does your door jamb sticker say for front axle weight rating? That will tell you what springs are in there. You can step those down one level to the next lower rating using a ford spring, will likely be a lot nicer.
Old Feb 10, 2025 | 07:27 AM
  #32
senecagreen's Avatar
senecagreen
Originally Posted by TCNashville
I removed the Bilsteins and put on a new set of Rancho 5000X shocks hoping the softer sprung shock would smooth out the ride a little and guess what, there is no difference in ride quality. Must've been in my head all along. But, as warned above, I have picked up some additional wheel hop. Jeez, I'm an idiot. Probably going to reinstall the Bilsteins. Thanks to all who contributed to this thread, Terry.
My 5100's seem to ride softer than when I first put them on but maybe Im just getting used to them. I put RC N3's on the back and they seem to ride better than the front but will wait till spring when I take the weight out of the back of my truck to decide about putting N3's on the front.
Old Feb 10, 2025 | 11:45 AM
  #33
Phillbo's Avatar
Phillbo
Originally Posted by BPTS
the truck is absolutely planted and corners like it is on rails and tows flat & smooth.
I'm confused, how does a shock impact ride height when towing? I would think if they were stiff enough to prevent sag that I would not want to hit a manhole cover for fear of my teeth.
LGMavin
Jun 18, 2023 07:53 AM
marv02
Jan 9, 2020 02:27 PM
rjfetz1
Sep 18, 2009 05:26 PM
typhus
1997 - 2003 F150
Feb 23, 2008 07:42 AM
