E303 supporting mods?
Old Nov 18, 2024 | 11:20 AM
Matt_Ced's Avatar
Matt_Ced
4wd Low
Hey yall I have a few questions about the e303 302 cam from summit. If I do end up getting this, What supporting mods should I get along with it? what power increase should I inspect? and should I advance timing or anything with the cam? I have my 83 F100 with a stock carb 302 and aod.
And if it doesn’t work, what cam should I look at?
Old Nov 18, 2024 | 01:21 PM
Max Capacity's Avatar
Max Capacity
Summit Racing had great customer service. Did you talk with someone there ?
Have you talked with the auto motive machine shop to see what they have had good luck with ? Here's an old family friend's shop that did are race engines.
https://eastwoodsautomachine.com/
Old Nov 18, 2024 | 06:27 PM
Franklin2's Avatar
Franklin2
Get ready, Summit is going to ask you what your rear gear ratio is. And you said you have a stock transmission. They are probably going to tell you that cam is too radical for your setup. You should go with a milder cam setup.
My boss at work is in the same situation now with a LS1 swap. He used a carb on it and has a very radical camshaft in it. It runs great wide open, but it won't idle hardly at all. We had to use a highly modified carb on it and it mostly works now. But he is still having to fight it some, I keep telling him take that camshaft out and put something milder in it, and everything will suddenly smooth out and work.
DoABurnski
Jul 19, 2021 05:58 PM
Colin1Blevins
Jan 27, 2018 02:40 PM
BIG-COUNTRY
Nov 29, 2005 08:58 PM
