Slow crank
Old Nov 19, 2024 | 12:56 PM
bwguardian's Avatar
bwguardian
Originally Posted by Pikachu
The cables aren't #2. The cable between batteries should be 1/0 and from battery to starter should be 2/0.
That's the positive side...what about the negative cables as they look to be a different diameter, but that could be just the sheathing...
Old Nov 19, 2024 | 01:00 PM
helifixer's Avatar
helifixer
https://custombatterycables.com/
I have bought several sets from them and they are the best I have found.
Old Nov 19, 2024 | 01:52 PM
Pikachu's Avatar
Pikachu
Well, that one I'll have to double check, but if I was to guess, I'd say those are each 1/0.
Old Nov 19, 2024 | 02:16 PM
helifixer's Avatar
helifixer
The ground cables are shorter and there are 2 of them so they can be smaller. Each cable only has to carry 1/2 as much as the positive cable.
Old Nov 19, 2024 | 05:19 PM
John in OkieLand's Avatar
John in OkieLand
Looking at a couple options, but this one has everything needed down to the shrink wrap. Would the stock cables be #2 3/8", which is what the copper lugs accept? Can these lugs be crimped to the cables with a good set of channel locks and/or by melting some lead in there possibly from the old terminal? Need to check the battery post diameter too for fitment...
https://www.amazon.com/gp/product/B0...59NLKDCV6&th=1
This might be another option for the lugs, but seems like just a hyped up local auto parts stick the cable into the hole and bolt down the nuts on either side until tight, which still leaves it exposed...not as big a deal with AGM batteries, but still.
https://www.amazon.com/Fastronix-Battery-Compression-Terminal-Positive/dp/B00X362H7W/ref=sr_1_2?crid=397NXRSS1PKXG&dib=eyJ2IjoiMSJ9.-0qKBBf_qVuNp_1CKSEX_64p0cGOkx1IMvgvaA3sGZGosweaXo2 gigPBBgL3K1sw_Hgfm_nibDo2jimqtvFLz4cCk10pr6_MIjPZ6 vcYdSrAhGVSb51WDhrFiUKECXF1D3YZr7aGZGHevwfmiMuta vUK-3VMV5tra0RGjqgbcCLvTEEKLSlaPTQsswTcoutvyddkt52BoXf OXyBrlOj4Z622mdCOs3ZW7QIKea8.zYK3AwrrB2JjkWt-dcbTpCphOuj6rfR--w9Uzqs964k&dib_tag=se&keywords=top%2Bpost%2Bbatter y%2Bcompression%2Bterminal&qid=1732028250&sprefix= top%2Bpost%2Bbattery%2Bcompression%2Bterminal%2Cap s%2C172&sr=8-2&th=1
Found this which might not be too bad, but I'll look at Harbor Freight too. Might could rig up something similar depending on fit...
https://www.amazon.com/AMZCNC-Hammer...s%2C150&sr=8-6
the first two options are a no-go
no way a pair of channel locks can apply enough pressure to crimp any connector, not even #22 wire. it makes a mangled mess.
the 3rd option, the Hammer blow crimper is useful, have used it since the '60s with good success, the appearance is less than what I want though.
those simple battery terminals with only the one bolt, are not good for more than ONCE in my opinion, yeah, people keep using them, but once and they are done in my book...
I go with the military style, or the multi-terminal type.
for the terminals on the 1/0 cables, I use a Hydraulic crimper, mine is from Amazon.. you need a GAS TIGHT connection between the Terminal and the Cable, and cheap crimpers just cannot apply enough force.
Old Nov 19, 2024 | 06:07 PM
bwguardian's Avatar
bwguardian
The first one is the military style terminals...are you just saying the 2-0 lugs are incorrect? I can't find any definitive answer on factory battery cable size for both positive and negative runs...
Old Nov 19, 2024 | 09:11 PM
John in OkieLand
I will just give you a picture of mine
Passenger side, Military Terminals
Drivers side, big multi-terminals.... never have to remove the post off the battery, I leave them alone.
Driver's side, big multi-terminals.... never have to remove the clamp terminal off the battery, I leave it alone.
the reason they look clean, is because I sprayed them with Fluid Film, they will, never, ever, corrode.
they stay wet looking all the time.
RigCity
15
Mar 3, 2023 02:46 AM
laloacosta
May 3, 2021 08:16 PM
Amicus
May 12, 2020 10:59 AM
kefrko
Nov 4, 2014 06:04 PM
jmbatlanta
Oct 29, 2006 06:05 PM
