Weird issue with hazards
Old Nov 16, 2024 | 04:26 PM
dj050894's Avatar
dj050894
4wd Low
1995 F150 XLT. I notice a weird issue yesterday when hooking up a trailer and testing the lights. When I turn on the hazards on the truck, only the front passenger side blinks, none of the other 3. However, they all flash properly when using the turn signals. Any idea what would cause this?
Old Nov 16, 2024 | 10:56 PM
GoinBoarding's Avatar
GoinBoarding
Only when the trailer is connected electrically? Bad ground?
Old Nov 16, 2024 | 11:51 PM
Truckie256's Avatar
Truckie256
the hazard button in my multi function stalk, is a bit wonky and acts up.
try wiggling it and see if anything changes
if fine without trailer hooked up.... wiring issue on trailer
Old Nov 17, 2024 | 02:11 PM
dj050894's Avatar
dj050894
4wd Low
It does it without the trailer hooked up as well
Old Nov 17, 2024 | 02:58 PM
Truckie256's Avatar
Truckie256
Really wiggle the Hazards button... if no changes, then try Hazards flasher in the fuse panel, then if flasher is cheap...no changes a new multi function stalk.. there are used oem ones on ebay but may be same or have different issues.
but it could be a bad ground on the hazard circuit, checking the circuit is free if you have the tools
Old Nov 17, 2024 | 03:04 PM
Soup bean's Avatar
Soup bean
Is your trailer connector aftermarket?
If it is, were crimp on butt splices used?
They're a good place to check for lighting issues. They can be used successfully, but it takes some technique to crimp them properly, or they make a poor connection.
Solder and heat shrink is a better way.
Old Nov 17, 2024 | 03:59 PM
dj050894's Avatar
dj050894
4wd Low
it’s a Curt harness. Was all plug and play, no splicing required.
Old Nov 17, 2024 | 07:05 PM
Soup bean's Avatar
Soup bean
Are the connectors fully seated? I've had to gently squeeze the harness connector near the rear bumper with channelocks, to get it to seat all the way.
Do you have any LED bulbs in the system? They can cause flasher issues.
kioolt
Electrical Systems/Wiring
25
Jul 20, 2011 10:36 PM
rebel_ford4x4
All Things Towing
Nov 12, 2006 10:32 PM
Rupes F1
Oct 4, 2006 05:30 PM
PaulRuffo
Jul 20, 2004 10:32 AM
rlp
All Things Towing
Sep 7, 2003 06:04 AM
