Crankshaft
Old Nov 15, 2024 | 10:00 PM
speedemon1084's Avatar
speedemon1084
Crankshaft
Needing a new crankshaft for a 2000 model. Any ideas? No where I checked seems to have them.
Old Nov 16, 2024 | 12:42 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Where are you located?
Old Nov 16, 2024 | 02:55 AM
udsuth78's Avatar
udsuth78
Are you needing a NEW crankshaft, a reman crankshaft, or another crankshaft? New I doubt exists, reman and used replacements are available. A quick search showed Kill Devil Diesel sells remans, and for used, eBay is king there I'm sure.
Old Nov 16, 2024 | 09:09 AM
speedemon1084
Would prefer new, but reman will probably have to work.
Old Nov 16, 2024 | 10:14 AM
John in OkieLand's Avatar
John in OkieLand
just a new crank will cost as much as a used engine
Old Nov 16, 2024 | 10:16 AM
speedemon1084
Originally Posted by John in OkieLand;[url=tel:21403776
21403776[/url]]just a new crank will cost as much as a used engine
Kinda what I was afraid of.
Old Nov 16, 2024 | 10:43 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
I'd have no problem buying used so long as it came out of a running engine that saw some semblance of regular maintenance. The journals are HARD. I have a crank out of a 970K (yes, almost million-mile) engine that I would have no problem putting in a rebuild.
Old Nov 16, 2024 | 11:56 AM
kenn_chan's Avatar
kenn_chan
OP you need to explain to us exactly what you did that makes you need a new crankshaft... inquiring minds want to know.
Old Nov 16, 2024 | 12:03 PM
speedemon1084
Originally Posted by kenn_chan;[url=tel:21403877
21403877[/url]]OP you need to explain to us exactly what you did that makes you need a new crankshaft... inquiring minds want to know.
Not me, previous owner. Leading theory is that when they replaced the clutch, the didn’t put the pilot bushing back in, causing play on the input shaft. All ten flywheel bolts broke inside the crank. Egg shaped some of the holes, crank is not salvageable.
Old Nov 16, 2024 | 12:05 PM
Pikachu's Avatar
Pikachu
Oh, noice.
Old Nov 16, 2024 | 08:15 PM
John in OkieLand
that crank is definitely a goner.
I don't see a way to fix that, unless a good welder fills the holes and rebores them.
Old Nov 16, 2024 | 08:44 PM
speedemon1084
Originally Posted by John in OkieLand;[url=tel:21404259
21404259[/url]]that crank is definitely a goner.
Definitely gonna replace it. Cause I want it fixed correctly. And that’s the only way that I know that is gonna happen.
Old Nov 17, 2024 | 02:29 AM
kenn_chan's Avatar
kenn_chan
didn't you have a post about a year ago asking how to get the broken bolts out?
Old Nov 17, 2024 | 05:01 AM
speedemon1084
Originally Posted by kenn_chan;[url=tel:21404387
21404387[/url]]didn't you have a post about a year ago asking how to get the broken bolts out?
Yes. I ended up taking it to a mechanic, the got the bolts out, then determined that the crank couldn’t be saved.
Old Nov 17, 2024 | 08:15 AM
kenn_chan's Avatar
kenn_chan
thats rough. he could not go with longer threaded grade 10 or 12 bolts? i remember reading somewhere there is a bit of depth in those holes that the stock bolts do not reach. not sure what the grade is on the stock bolts, but a 10, or 12.7 is pretty stout compared to what you normally see on light vehicles.
