View Poll Results: What to do about those wheels
fix/shine the wheels
66.67%
throw them out and get steelies
22.22%
6" lift kit with 10 lug hub, 22.5 alcoas and spikes for the ladies
11.11%
Voters: 9. You may not vote on this poll
Tires going flat
Old Feb 19, 2025 | 09:42 PM
gator398's Avatar
gator398
Those wheels look fantastic, great work. I will definitely have to do mine one day, because problem solved!
I asked around local tire shop that's been in business since 1967 and has tons of pictures of classics and 80's, 90's trucks. They said no problem to fix this and the bead corrosion is usually only an issue on Northern road salt zone wheels. They said they cleaned up surface and replaced the valve stems, and if they didn't hold the air over next month to bring it back in and they will use a different style valve stems.
1 month later, no drop in pressure. I'm buying my tires from this shop from now on, great folks there. They only charged $40 to do this and took them a little over an hour.
ljutic ss
6.4L Power Stroke Diesel
Oct 10, 2013 06:06 PM
cc322
Jan 26, 2010 06:09 PM
ALBUQ F-1
20
Jan 13, 2010 11:10 AM
spikedog
Jan 30, 2004 08:13 AM
