The bms update from earlier in 24
addressed a bunch of battery charge issues
You csn also in forscsn chsnge stare of chrage to 95% vice 90%
if you dont drive much...get a battery tender or charge it once a week
So when you change the battery to AGM in FORScan it automatically changed the BMS configuration to LIN instead of PWM.. so my settings look juts like yours.
the factory flooded battery is so mis shaped “damaged looking” no reason that should have been installed in a new truck these days I purchased mine in December.
Thank you so much! sorry about that I seen you put the info in a previous post… so all I changed was the battery to an AGM which I used Deka aka which is sold O’Reilly’s , Sam’s, Walmart or Napa. Johnson Control who was sold to Clarios.. who makes batteries for AutoZone and Costco… I read alot about these battery companies for work.
No problem at all. I also prefer Deka over JC batteries and have for a long time.
