Another 2023 Superduty Battery Problem
Old Nov 18, 2024 | 02:09 PM
seijirou's Avatar
seijirou
My gasser came with AGM batteries, but it came with 2 batteries and dual alternators as well. Not sure if that has an influence on getting AGM or flooded.
Old Nov 18, 2024 | 02:19 PM
Zork's Avatar
Zork
It is.
That's one option I wished my XLT came with also. Good stuff.
Old Nov 19, 2024 | 06:52 AM
OX2's Avatar
OX2
Any reason the 'flooded" guys wouldn't just "upgrade" to the stock AGM?
Old Nov 19, 2024 | 07:46 AM
Zork's Avatar
Zork
If you buy it off the lot, that's not really an option!
(...at least not a cheap one)
I replaced the flooded battery with a Walmart AGM within a month of ownership.
Old Nov 19, 2024 | 07:59 AM
OX2's Avatar
OX2
Yes, I meant buying new batt's after delivery. Did not know how the stock AGM's compared in quality to others.
Motorcraft batt's used to be one of the best for years, back in "the day".
Old Nov 19, 2024 | 09:39 AM
Charlie98's Avatar
Charlie98
I would think an OEM battery would be decent enough that it wouldn't leak 4 months after I bought it. A good flooded battery is, well, a good battery... there is nothing wrong with them, and no reason it shouldn't last 2-3 years before needing replacement.
Old Nov 19, 2024 | 10:04 AM
OX2's Avatar
OX2
Agree. My other thought is if you go with stock AGM (over flooded), might be more warrantee friendly, if/when you have any charging or electronic issues..
(and a "crappy" dealer tries to start blaming aftermarket battery).
Old Nov 19, 2024 | 10:10 AM
techfile's Avatar
techfile
Besides using Forscan to reprogram the truck for an AGM battery, does dealer software also have this capability to change the charge profile to AGM?
Old Jan 9, 2025 | 09:33 AM
mscott2's Avatar
mscott2
Trailering
Originally Posted by B767capt
Here you go Charlie. My truck is a 2024.
This picture is in the section with the wrench. My arrow is on BDY CM and battery monitoring system.
This is what the next selection is.
Here you change to configuration which is the one below the wrench symbol. Go to the plain english one for bdy cm module config
Slew down to this
Then change it here.
thank you so much ! Mines a 24 also! I also added remote
start from the key fob by just adding the oem key fobs with remote start on them! Same frequency 433/434. It works awesome.
Old Jan 9, 2025 | 09:36 AM
mscott2's Avatar
mscott2
Trailering
Is it only the diesel's that come stock with an AGM?
and trucks like the f150 with auto start/stop junk
Old Jan 14, 2025 | 05:37 PM
mscott2's Avatar
mscott2
Trailering
Slew down to this
I got my AGM battery so question do you changed the battery first then run FORScan to change the setting?
Old Jan 15, 2025 | 09:51 PM
mscott2's Avatar
mscott2
Trailering
hey do you have FORScan? If so would you take a screen shot of the settings for your battery? The BdyCM screen where the BMS configuration starts please
Old Jan 15, 2025 | 11:21 PM
  #28
seijirou's Avatar
seijirou
Yeah I'll get that for you tomorrow.
Old Jan 16, 2025 | 08:59 PM
  #29
seijirou's Avatar
seijirou
Is this what you wanted?
Old Jan 17, 2025 | 08:05 AM
  #30
mscott2's Avatar
mscott2
Trailering
yes thank you so much, was yours a original factory AGM battery?? What year is your F250?
you haven’t changed any of those BMS settings?
