Sponsored by: Real Truck
P0678 and more
Old Nov 14, 2024 | 03:01 AM
Work or Play?'s Avatar
Work or Play?
P0678 and more
Greetings! My personal truck is a 95 F250/7.3. My neighbor has a '03 F250 with a 7.3 that's throwing P0678, P0676, P0674, and P0672.
I had issues with mine in the past but only coded for 1 glow plug. Ended up using the "quarter trick" on the under valve cover connection and haven't had any further issues.
My question, before I start tearing into this other truck is, has anyone had the entire bank throw the glow plug code(s) and how did you remedy the issue?
In other words, aside from looking for chafed insulation on the exterior wiring, where should I start? Weather is trending towards snow and the Gal needs her 4x4 to get around. I'm hoping to get this fixed for her pronto. Thanks in advance for your input.
Last edited by Work or Play?; Nov 14, 2024 at 10:00 AM. Reason: Called out wrong part
Old Nov 14, 2024 | 06:52 AM
Pikachu's Avatar
Pikachu
Those aren't injector codes, they're glow plug codes. Start by checking the resistance from the valve cover gasket through each glow plug.
Old Nov 14, 2024 | 10:04 AM
Work or Play?
Pikachu, of course. You are correct. I called out the wrong part. I was indeed speaking of glow plugs, not injectors. Thanks for catching that.
1979-f-150
Jul 7, 2024 08:59 AM
Red7.3dually
Apr 8, 2023 07:11 AM
Rdavis008
20
Feb 5, 2023 11:04 AM
Eastman Anthony
Dec 22, 2011 09:45 PM
k2vailkid
19
Oct 4, 2007 12:58 PM
