Hello folks. brand new user.
I have a 2006 F250 super duty 5.4
recently the blend door that controls temp failed. It has an actuator for temp and one for location of air flow. location of air flow is working fine. temp is full heat. I replaced the actuator with no results. I have checked fuse (24 under dash) and its fine. on board diagnostic shows a code 22 66 with a Celsius symbol on 22. It seems I'm not getting power to the actuator testing with light.
