'03 Excursion - Steering Wheel Radio Controls
Old Nov 13, 2024 | 08:18 AM
SAARNO's Avatar
SAARNO
3rd Gear
Has anyone experienced a problem with the wheel controls for the factory stereo system? I've found that my volume controls now change the stations and sometimes band selection. Prior to that, pressing the volume down would actually bring the volume up. The station selection sometimes changes the band, too.
I have an '03 Limited with factory sound system.
Old Nov 13, 2024 | 02:15 PM
Excurvelle's Avatar
Excurvelle
Carefully clean the switches, good ones are very rare. You can carefully remove them from the steering wheel with a plastic tool.
Last year I found a new set in Great Britain from a limo company, my cruise control was not working.
Old Nov 14, 2024 | 12:44 PM
John in OkieLand's Avatar
John in OkieLand
on my '02 Excursion, when I replaced the steering wheel,
I noted that the plugin connector in the base of the steering wheel is easily damaged, inspect it for proper seating.
I bought an Eddie Bauer steering wheel for my XLT and assumed ( yeah ) that the ribbon connectors were all the same.
they are, and they aren't.
Eddie Bauer is reversed upside down, compared to the OEM XLT steering wheel.
I tried to seat the new ribbon cable, it didn't fit, at the time, I was having eyesight issues, and could not see what I was doing, so I pushed harder, and broke the connector.
got a magnifying glass, and saw what happened, removed the cable, turned it around 180 degrees and it snapped right in, as it should.
fordboy67
Jul 15, 2013 07:40 PM
stroken
Apr 9, 2008 12:40 AM
KRDiesel
Feb 12, 2008 12:41 PM
ibyourhucklebery
Oct 15, 2007 11:25 PM
Glock 19
Dec 27, 2004 10:06 PM
