Sponsored by: Real Truck
f550 FUEL ISSUE
Old Nov 12, 2024 | 10:55 AM
ppikmi9959's Avatar
ppikmi9959
2nd Gear
f550 FUEL ISSUE
I have a 2008 F550 with a 6.8 v-10 and fuel tank behind the rear differential. It is not getting gas and will only start with starting fluid.
My questions are;
Should I hear the fuel pump run when the key is turned on?
I've disconnected the fuel line that feeds the fuel filter on the frame rail and turned the key on, should fuel pump out? (The line is bone dry inside.)
The electrical connector to the pump/sending unit/etc. is an 8 position connector with only 7 positions being used. Only one of the pins coming from the front of the vehicle show power when the key is turned on. Is this normal?
Old Nov 12, 2024 | 01:29 PM
shaun.be's Avatar
shaun.be
If you have one pump you should have power to that pin with the key on but just for a short bit to prime the system. Did you check the inertia switch?
Old Nov 12, 2024 | 02:39 PM
ppikmi9959's Avatar
ppikmi9959
2nd Gear
I did check the inertia switch and it has not been tripped.
fireman2
13
Jun 24, 2020 07:11 PM
sand1
Oct 22, 2016 06:05 AM
capitanjo
20
Nov 24, 2011 03:18 PM
