Steering box lube
Old Nov 12, 2024 | 01:28 PM
abe's Avatar
abe
Originally Posted by 1952henry
As an aside, the corn head grease is “0”
Intersting... So what has a thicker viscosity, 00 grease or 0 grease?
Old Nov 12, 2024 | 01:43 PM
1952henry's Avatar
1952henry
0 is thicker. Many different brands of corn head grease. If the label says polyurea NLGI 0, there it is.
Old Nov 12, 2024 | 01:50 PM
Steve's Avatar
Steve
I had to look up what a corn head is...turns out it's a farm machinery gearbox. The grease is not made from corn! Who knew?
Anyway I'm in. Is the stuff compatible with regular EP gear oil?
Old Nov 12, 2024 | 02:27 PM
1952henry's Avatar
1952henry
It has been suggested a gearbox gets flushed first. I know some greases don’t play well with each other, I believe that has more to do with the type of thickener.
Old Nov 12, 2024 | 03:20 PM
abe's Avatar
abe
I drained mine thoroughly but did not flush it.
Old Nov 12, 2024 | 06:08 PM
Steve's Avatar
Steve
Hey Abe, How did you drain it? Through a low bolt hole on the front cover?
Old Nov 12, 2024 | 08:44 PM
abe's Avatar
abe
I should have said the F350 box was not in the truck so I turned it upside down and drained it into a basin. I don't know the best way to drain it while still in your truck.
How do we know if the corn head grease mixes well with the old ?
Old Nov 12, 2024 | 09:03 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
This bolt hole opens into the housing cavity and will drain it. You might need to use brake cleaner it to rinse it out.
Old Nov 12, 2024 | 09:34 PM
abe's Avatar
abe
That is one gunked up steering box!
Old Nov 13, 2024 | 07:09 AM
fordf348's Avatar
fordf348
I use 140# gear oil in my transmission, differential and steering box because it is in my hand.
Old Nov 13, 2024 | 08:34 AM
Steve's Avatar
Steve
So in the end I think I won't use the corn head grease. I read that it is designed to become somewhat fluid when it is worked/agitated in moving machinery, but steering box internals aren't really in constant motion. Also, in my mind, bushings need a more fluid lubricant to stay happy, and the CHG doesn't pass this test. So I am gonna go with the Pennrite Steering Box Lube which is a 1200w which flows a little better and gets good reviews with regards to not leaking out. It's probably similar to the 00 grade stuff that Abe used. I'll post up what I discover when I try to get it into the box.
Old Nov 13, 2024 | 11:10 AM
1952henry's Avatar
1952henry
I don’t know anything about the 1200w oil, but Pennrite’s semi fluid steering box lube is the same stuff as TSC “00” , just 3-4 times the price.
NJZouave
16
Jul 11, 2023 02:56 PM
vidaliaman
May 20, 2021 01:08 PM
seawulff
Jul 10, 2018 03:54 PM
Oakroadjoe
Dec 28, 2014 07:00 PM
Crumm
Dec 2, 2003 11:42 PM
