Sponsored by: Real Truck
gear swap ?
Old Nov 11, 2024 | 04:58 PM
V10man's Avatar
V10man
gear swap ?
I'm planning on swapping my 3.73's to 4.30's on my 2001. What I'm wondering is should/do I need to, reprogram the computer? I was also thinking of getting a tuner from 5 Star. Can I change it with that or can they change it when they program it? Headers and freer flowing exhaust are on the list too.
Old Nov 12, 2024 | 09:27 AM
Diamnd1's Avatar
Diamnd1
I had a gear swap to 4:30 in mine by the dealer service dept and said they did a re-flash. I do have 5 Star tunes and did inform them of the gear swap when they customized my tow tune.
Old Nov 12, 2024 | 10:57 AM
nydiver's Avatar
nydiver
Forscan should be able to adjust for the gear ratio.
Old Nov 12, 2024 | 01:24 PM
shaun.be's Avatar
shaun.be
You don't need to adjust for speedometer to read correctly as it reads off the tone ring in the rear end and the front speed sensors, you do have to adjust if going bigger tires though.
Old Nov 13, 2024 | 09:37 PM
GOT-DRT's Avatar
GOT-DRT
Can I ask y’all we did it cost to do the gear swap on both pumpkins
Old Nov 14, 2024 | 08:02 AM
nydiver's Avatar
nydiver
Gears are around 250-300 for the set, master install kit with bearings and shims is around 150, so figure ~1000 to regear yourself. Obviously you can find deals and try and chisel that down a bit. I'd recommend Ron's machining if you want to do it yourself. https://www.ronsmachiningservice.net/new-category-142/
Old Nov 14, 2024 | 01:36 PM
Diamnd1's Avatar
Diamnd1
Re-gear at the dealer with gears, master rebuild kits and labor for both diff was $2800.
429PI IN 75 f-100
Apr 18, 2009 07:38 AM
Paul Crowther
Nov 24, 2004 09:17 PM
