2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
Known control arm issue?
Old Nov 21, 2024 | 10:27 AM
jayhitek's Avatar
jayhitek
Originally Posted by RossRR
It would be interesting to try to recreate the event with another truck with adaptive cruise and lane centering and see if the software is the culprit. I know mine tries to dive right or left under certain conditions, particularly when it encounters an exit lane.
I'm not sure you would get the same result. I was holding my steering wheel straight when it went hard left. It was definitely pushed from the back right corner that made it go left.
Old Nov 23, 2024 | 08:10 AM
Split rims's Avatar
Split rims
You folks affected by this issue really need to report it.....
https://www-odi.nhtsa.dot.gov/Vehicl...nt/index.xhtml
Old Nov 23, 2024 | 02:48 PM
Papa Tiger's Avatar
Papa Tiger
After you look at the tire marks on the highway and rule in a blown tire as your culprit;
Did you experience a hard pull / spin to the steering wheel just prior to bang. I have seen
others dart across the expressway and into a barrior.
There is usually a Tie Rod / Ball joint/ link issue.
A quick check at Midas will give you options. But if you're totaled just learn some ?
If you also had a buzzing sound it may link the wheel bearing into the options also.
I had a Right rear Tubeless blow at 55 mph, on a large 59 Impala, try to throw me into a ditch in 1965.
Johndg1991
Dec 22, 2022 11:00 AM
Jake05444
2015 - 2020 F150
Sep 29, 2019 01:29 PM
BioBurner
Jul 21, 2016 04:39 PM
Tom
Aug 13, 2010 09:15 PM
bryank1202
Feb 12, 2009 01:04 PM
