Turbo Charged Flat Head v8
Old 12-26-2005, 07:49 PM
UnderPSI's Avatar
UnderPSI
UnderPSI is offline
I would not run remote mount on a flatty, I'm thinking twins up front. It's a '48 239. Still looking for a 4" crank. I have not turbo'd a flatty yet, and I'm dying to see how well it works. I think it will do great.
  #32
Old 12-27-2005, 12:16 AM
45ford's Avatar
45ford
45ford is offline
In 1973, a flathead historian and Bonneville racer named Mark Dees wrote a four-part article published in Rod & Custom entitled "A Technical History of the Racing Flatheads." This article was reprinted in 1978 in the Early Ford V-8 Club's V-8 Times magazine.
In it, while talking about superchargers and the flathead, he said, "The Ford V-8 is about the worst prospect in the world for turbocharging, even with a modern Airesearch unit."
Today, though, maybe with fuel injection and a state-of-the-art computer...but then, you might just as well buy a a modern five-main-bearing engine to hot rod.
Mike
  #33
Old 12-27-2005, 01:01 AM
UnderPSI's Avatar
UnderPSI
UnderPSI is offline
1973 isn't very modern anymore, turbo's have coma a long way.
Mike
That would take all the fun out of it. Modern is very easy.
  #34
Old 12-27-2005, 10:17 PM
Dodge41's Avatar
Dodge41
Dodge41 is offline
Mike
Do you still have a copy of that article you could post? I would love to read an article written by a flathead historian and Bonneville race car driver.
  #35
Old 12-28-2005, 12:55 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
I'd have to say that just about everything possible has been done to the flathead ford.
Ya just have to have enough talent or money. Most hobbiests don't have enough of either.
They used to run the "Baby Flathead" (V8-60) upside down in the sprint cars, Ground the cam so that the intake and exhaust valves were swapped. It would sit lower in the chassis and give better weight distribution.
I am also of the opinion that unless you just want to say "I have a Turbo Charged Flathead", your wasting your time and money.
Also the part of the discussion about using the newer small superchargers, those are "Dry Systems" made to have the fuel mixed in after the air is compressed.
  #36
Old 12-29-2005, 04:52 PM
captchas's Avatar
captchas
captchas is offline
Guest
i don't remember ever fitting a 4inch 49 to 53 merc crank into a 48 or early style block. if it does you will have clearence problems to work out. your talking a 8 series crank into
59 series block.
the 48 is 239 inches just a diferent motor.
  #37
Old 12-29-2005, 07:51 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
59 series block.
The 48 Truck was the first to use the 8 BA/RT Engine, the rest of the Ford Mercury line got it in 49.
  #38
Old 12-30-2005, 11:52 AM
captchas's Avatar
captchas
captchas is offline
Guest
then all you need is the crank and rods from the merc motor. i did my 53 f100 that way plus a .060 over bore. about 263 inches. with the iskie cam, offie heads and 2x2 stromburg carb set i had in storage . o such a sweet sound. when camming a flatie be sure to carfully check to make sure the valves don't hit the head. by useing modleing clay when hand turning mine i found they would have hit.
my 8rt block had to be sleved on 2 bores, crackes, and new valve seats installed to handle lead free gas.
but to a old fart like me there is nothing like a flatie sound with a pair of glass packs
  #39
Old 12-30-2005, 01:29 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
It is the crank and the pistons that need to be changed . The Merc pistons have a different pin location to work with the 4 in crank.
You have to be careful with the cams as you stated, especially when using aftermarket heads and when swapping/shaving stock heads.
  #40
Old 12-30-2005, 06:07 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
So you like the sound of a Flathead, Check this out
276 CI built by Ron Hollaran with an Isky 400 Jr.
http://media.putfile.com/400jr-sound
  #41
Old 12-30-2008, 01:47 AM
fastkiwi's Avatar
fastkiwi
fastkiwi is offline
Hi i am new to the site and want to twin turbo a flaty am in the prosess of rebuilding a 30A coupe 48 flaty toyota 5speed box 48 jailbar diff wire wheels . more talk on the turbo from the people who KNOW Please
  #42
Old 12-30-2008, 03:52 PM
effie_man's Avatar
effie_man
effie_man is offline
you read my mind.... Smithy's all the way
  #43
Old 01-03-2009, 09:11 PM
55 f350's Avatar
55 f350
55 f350 is offline
i had a chance at a swap meet to pick up a complete turbo kit meant for a newer fox body stang , real cheap . the same idea your having ran through my brain at 200 mph . then some experts on another forum talked me out of it claiming that the extra heat would crack valve seats and a whole long sundry list of things on my old flatty . who knows for sure till ya try ....
  #44
Old 01-17-2009, 06:59 PM
F6Guy's Avatar
F6Guy
F6Guy is offline
the mallicoat brothers ran twin turbos with a drawthru setup in 1964 and blew the doors off all the stroked blown himis with a a little 327 chevy. It took time but they made it work. Now a flathead is no small block chevy but I think with the proper sizing and with fuel injection it could work well. Turbo engines tend to run cooler than supercharged engines. I would love to try it myself but time and money are things I am short on. Of course it stands to reason that someone would have done it bynow if it was worth a damn. But i would still loke to try it. As far as intercooling I think it would not be needed with 5-7 psi boost.
firstrider
Ford Truck Parts for Sale
05-24-2017 03:07 PM
mtrickel
19
01-05-2017 06:48 PM
wardsd
02-01-2016 08:55 PM
car.rebuilder601
1947 and Older Ford Trucks
05-08-2012 02:31 PM
Aaron-71
07-14-2011 04:48 PM
Quick Reply: Turbo Charged Flat Head v8
