What size Tires
Old Nov 5, 2024 | 03:40 PM
kitz's Avatar
kitz
What size Tires
I have a 97 f250hd obs with diesel what is the biggest tires you can put on without a lift and rubbing it has 235/85r16 now but they just don't look right thanks
Old Nov 5, 2024 | 06:04 PM
85e150's Avatar
85e150
Thread moved--lots more traffic here and folks with the same truck to let you know what hits and what fits.
Old Nov 5, 2024 | 06:42 PM
cougrrcj's Avatar
cougrrcj
The 235/85-16s, when new (at 31.7" diameter) < almost > hit the front bumper plastic air dam/spoiler when the wheels were slightly turned on my previous '97 F250HD with the factory 16x7 Alcoa aluminum wheels.. Probably less than 1/2" clearance. I had a set of snow tires in 275/75-16 (32.2" diameter) on slightly wider 8" steel wheels. Those DID contact the plastic air dam when the wheels were turned, so I was forced to trim the plastic air dam slightly. OR I suppose I could run without the air dam, but I liked the look with the dam on...
Old Nov 6, 2024 | 02:03 PM
OBS460's Avatar
OBS460
I had 285/75r16s (32.8" tall x11.2" wide depending on manufacturer) and they didn't rub with stock rims.
Old Nov 8, 2024 | 06:00 AM
TGrizzle's Avatar
TGrizzle
6th Gear
A few tire-related questions
New member, new question:
Sorry if I am running counter to group etiquette here, I can's find a place to start a post, only a "reply"... here goes.
So I have a 1994 F-150 XL 5-speed and I-6 motor (1-year now) and I absolutely love it. Stock tires are the 235/75R-15. I joined Costco for a deal on hearing aids and discovered they have good tire prices. I wanted Michelin but they don't make 15" tires anymore. I'm looking at buying new wheels, 16" or maybe 17" (if not too large), depending upon what the wisdom of this group is. I found that Dodge Dakotas run the 5x5.5 bolt pattern in a 16x8 wheel but the offset is +25mm. I think stock F-150 in this year had a -44 to +44 mm offset, which must mean zero offset? That's one question, is that true, zero? Let's say it is zero offset, would a +25 mm make the wheel poke out a little more than OEM? And one last question, would 17" work and be desirable, not too stiff since the sidewall would have to be shorter.
thanks.... tgrizzle
Old Nov 8, 2024 | 07:07 AM
eldomike51's Avatar
eldomike51
I put 265/70R-16 on my 1996 F250...I like the way they fill the wheel wells up and have no rubbing...
Old Nov 8, 2024 | 08:34 AM
TGrizzle's Avatar
TGrizzle
6th Gear
That is a beautiful truck, and the tires don't look dorky, like, too big, not stock, so I'd say you succeeded by using the 265/70's with those 16" wheels. Thanks for that information.
Old Nov 8, 2024 | 08:54 AM
TGrizzle's Avatar
TGrizzle
6th Gear
Do you remember what the offset is for those wheels?
Old Nov 8, 2024 | 09:26 AM
GoinBoarding's Avatar
GoinBoarding
thanks.... tgrizzle
Correct on zero offset being stock. Positive offset wheels will tuck them under the truck more. The center hole on a Dodge wheel may not be big enough to fit over a Ford hub too. Is your truck a 4x4? Lifted or stock height? 31x10.5R15 is a good sized tire for a stock 4x4. Can't beat factory forged alloy Alcoa wheels in my opinion. They're strong.
Old Nov 8, 2024 | 09:35 AM
eldomike51's Avatar
eldomike51
stock Ford wheels
Old Nov 11, 2024 | 07:33 AM
TGrizzle's Avatar
TGrizzle
6th Gear
My 1994 F-150 is a 2 x 4. But thanks for demystifying the + vs. - offset. So a +25 would make the wheels stick out less. And I did not think about the center hub diameter, I'll check that too before buying new wheels. I want to put Michelins on and they don't make a 15" for my application that Costco sells. This is why Im going down this road.
Thanks... tom
Jorgem2
Dec 27, 2023 07:18 PM
mattk15
Dec 14, 2003 02:23 PM
sweetsugar
Nov 15, 2003 11:57 AM
cmr
1997 - 2003 F150
Jun 10, 2000 07:32 AM
