1990 ranger 2.3
Old Nov 12, 2024 | 07:18 PM
Joshm12400's Avatar
Joshm12400
4wd Low
Truck still not running...changed TPS sensor, put old fuel pump back in and no change....with key on engine off my fuel return line is flowing back into tank nonstop, also now I'm having the issue while truck is idling (rough of course) the fuel pump is shutting off loosing power until I cycle the new a few times...sometimes fuel pump isn't coming on with key same thing just cycle a few times...does this sound like a computer issue??
Old Nov 12, 2024 | 07:20 PM
Joshm12400's Avatar
Joshm12400
4wd Low
Also yes I used starting fluid LIGHTLY around all vacuum hoses and intake with no difference in idle,,however when I sprayed lightly directly into throttle body while at idle it almost killed it like it drowned it out convinced I'm getting too much fuel at this point should have a pressure gauge tomorrow!
Old Nov 13, 2024 | 10:45 AM
tomw's Avatar
tomw
Read post #13 last section. ECM? Read it again.
MvW
Feb 18, 2017 06:00 PM
mattdumayne
Jun 12, 2011 07:33 PM
Terrence
18
Dec 15, 2006 12:52 PM
