Making heater work faster?
I'm asking because it's becoming winter fast (snow/rain today) temps in the 20s-30s in the mornings and nights. It would be nice to have a slightly more efficient heater.
Not much else you can do, the coolant needs time to warm up.
How long is it taking to warm up? Pickups usually warm up pretty quick with a small cabin to heat.
The 4.9 and 5.0 don't make the volume of heat the larger motors do, I have found it helps to block off part of tthe rad in winter months to help get the engine get up to temp faster.
I tyrapped my vacuum operated outside air door, so it stays in recirc position.
I've known two people personally in the last year, who's emergency brake cables broke, (manual transmissions) and their vehicles rolled away, while idling, so now I'm a wheel chocker.
True, there's no perfect seal on the thermostat (usually has an air bleed and a metal to metal seal that is imperfect) but the volume of coolant through it is inconsequential (or should be) in keeping the engine from warming up.
The best way to get the engine warm and producing heat is to put a load on it (especially a diesel!) but these days it seems that people just expect to start the engine and go back to their heated home, have a clear windshield within 34.25 seconds, and drive away toasty. Windshield scrapers exist for a reason but standing out in the cold wearing shorts and flip-flops while holding a double chai frappe latte for an extra minute is way too hard. I see that "dressing for the conditions" escapes a lot of people these recent years. I want to say to some of them, "You moved from Texas to Montana - it gets winter here sometimes. Time to accept your mistake and bundle up."
Also, one more thing to consider is that it will take varying amounts of time for perceptively "warm" air to come from the heater depending on ambient temperatures. Getting to, say, 60 degrees of coolant temperature on a 20 degree day (starting with 20 degree coolant) is only a 40 degree rise and the air blowing across the heater core has to only absorb 40 degrees of heat with the cold air blowing across it. Change those ambient/initial coolant numbers to -30 degrees and the temperature differential is 90 degrees - quite the difference to make up and quite the air temperature difference to overcome in a heater core with 30 square inches of surface area. It's simply going to take longer and there's no way around it.
But if you block some or you let it fully warm before driving, it will stay in the more cozy 190-200
Ive noticed this on other vehicles too.
Plug it into a timer that energizes it about 2 hrs before I need to drive. When I go out to the truck the heater core has warm coolant in it already due to the percolating effect.
Heater taps into lower block drain is installed back into heater hose and I attached the pump itself to passenger front frame rail.
Works really well
My work commute is very short, like 5-7 minutes (dry roads). My heater used to start getting warm by the time I'm almost there. Lately it takes a very long time, if at all. Suspecting the blend door.
302
I don't let it warm up by idling. Usually, the idle sequence is my warm up, or however long it takes to dig it out and scrape the ice off.
The one issue with plugging it in, 3 days a week, I have to leave at 4:45. However the outlet timer would negate that.
Coolant heater is not a bad idea, and would really help with defrost.
Like if I'm just going to run to town, I'll warm mine up for 5 minutes, then stop at the town park or something, and let it idle, or not shut it off at the bank drive through.
I've always heard that short trips are harder on engines.
I've heard short trips lead to excessive carbon buildup, so maybe I'll try the "water trick" sometime. I really can't lengthen the ride. However when I need to refuel, I drive like 20-25 minutes away, (that station is a lot cheaper as well
) so it can get fully warm. It's also a hilly drive, so the engine gets a good workout.
Works really well
https://polarind.ca/heat/
OP. 5 minute drive isn’t going to do much unfortunately. I’d get a block heater of some type, and timer. I usually warm things up in winter. Mostly because I don’t like rock hard cold seats...
It is hard on the exhaust for one, all it does is collect water moisture and continually builds up in there, eventually rusting it out. Moisture also collects in the oil and engine internally. Builds up over time. It needs to get up to temp to burn that moisture out.
I had some strange marks on my 351 cam that I showed around to a few people, none of us could figure it out. They cleaned off with solvents. Only theory I came up with was very short runs in the cold. 1-2 minute or less. Ie, truck is in the way, -35c, need to fire it up and move it, no time to run it. It runs for just enough time to develop moisture Vapor internally, but not enough to warm any components internally. Shut down, moisture falls out of suspension, collects on areas like the cam lobes and refreezes instantly, frosts it if you will, similar to frosting a spark plug. Next time you turn it over the moisture droplets drag and leave marks. One small example of possible moisture collecting.
Anyway, short tripping cold vehicles can be hard on them. Go get a coffee with it, lol.
