Antifreeze % fix?
Old Oct 29, 2024 | 08:12 AM
Tommy_Toohigh's Avatar
Tommy_Toohigh
Antifreeze % fix?
Can't get enough antifreeze in just the radiator after replacing the popped bypass hose. Flushed all the old stuff out (with the hose off);
Refilling the radiator, it'd only swallow about a gallon, and I'm nowhere near 50/50, tester of course sez: WEAK
Tips to drain enough to add a couple gallons? Looks like capacity is 17qts...
Old Oct 29, 2024 | 08:17 AM
Max Capacity's Avatar
Max Capacity
FWIW, I used a small shop vac to suck the old coolant out of the block when I had the water pump off. Can you suck coolant out from that bypass hose ?
Old Oct 29, 2024 | 08:27 AM
Tommy_Toohigh
Shop vac, sure
Oh, sure, worth a try. Huh
Old Oct 29, 2024 | 10:23 PM
J. Bruce's Avatar
J. Bruce
If I have been flushing a cooling system with water when done I usually add half the system capacity worth of concentrate then top up with water. You can use one of those floating bulb tester things to see the concentration. We have to run a little stronger than 50/50 so I error on the side of stronger when doing this. Just my 2c.
Old Oct 30, 2024 | 09:14 AM
Olds64's Avatar
Olds64
Apparently, the 5.0l has block drains just like the 6.9l & 7.3l IDIs during those years.
https://www.ford-trucks.com/forums/1...ain-plugs.html
Remove the block drains so you can replace the coolant with good 50/50. I use 70/30. You can take the drains to the hardware store and get P E T C O C K S (dang auto-censor) of the same thread so your next coolant flush will be easy.
Rhizzlebop
Jan 8, 2024 01:22 PM
1994F2507.3L
Jan 12, 2011 12:15 AM
triskit16
15
Nov 14, 2008 01:32 PM
Lance1601
1997 - 2003 F150
Jun 2, 2008 04:48 PM
mattd17
Modular V8 (4.6L, 5.4L)
Jan 15, 2006 10:12 PM
