Oil Choice and info!
Synthetics are alright, but ask others besides me for advice.
I just ordered 16 quarts of AMSOIL ATF for my 4r100a trans in my Expedition. It is full synthetic and I have never heard anything bad about it. The results of independent tests are pretty impressive. It is pretty expensive. Any quality ATF fluid should keep your tranny happy (again Mercon or Mercon V depending on your dipstick).
The transmission should be done atleast every 30k. It is also important to drop the pan to inspect the condition of the transmission and replace the filter. The filter does not typically get replaced if a "flush" service is done. There seem to be a lot of slipping problems noted in the 45k - 60k range if the transmission has not been serviced (4r70w & 4r100a transmissions).
The rear differential can easily go 60k miles if you are not towing or it has not been submerged in water. Check the level every 30k to be safe.
Hope this helps.
Ford specifically says not to use a dual rated MERCON/MERCON V fluid in the 4R100.
Lots of people do.
I'm just telling you what Ford says.
I'm not trying to plug AMSOil, but I believe in their products. I didn't say anyone else should use AMSOIL ATF, just that I am going to. AMSOIL actually addresses this myth about dual rated ATF in Ford transmissions. Its interesting to read, give it a look. I've done enough research to make up my mind that the AMSOIL ATF is the product that I want in my transmission.
Thank you. Everyone has an opinion about oil. I also have a motorcycle that has a Harley motor. Harley said never use synthetic oil in their bikes....that was until they came out with their own synthetic oil...now they recommend synthetic. I am putting AMSOIL in the bike as well.
Where on the Amsoil site is the comparison of MERCON to MERCON V. Link please.
I didn't make the Harley analogy very clear. My point is that the manufacturer is covering their *** (rightly so). But they don't necessarily have your best interest in mind.
1. Dont get caught up in the Amzoil MLM scheme. It will make you disliked far and wide by most normal people, well, me anyway.
2. Most people that tell you they've had really good results with Amzoil, are probably trying to sell it to you, and therefore cannot be trusted. You'd be surprised at some of the stuff they've said.
If you're gonna use it, that's cool, by all means go right ahead. Just be carefull who you listen to, and make sure you make it painfully clear that you aren't a dealer when you tell anyone that you use it.
That aside, I'd still trust Ford's word before Amsoil. If you dont save the receipt from Amsoil showing that you purchased x number of quarts of their transmission fluid, and have the installer sign that he did in fact install said fluid in your transmission, along with the mileage, how likely do you think it is that Amsoil will honor their warranty? Something else to get that pot stirring good.
I made it as clear as possible that I was not trying to promote AMSOIL. I have only heard good things about it and read independent tests (not AMSOIL's) that showed it provided good results. No one has ever tried to sell me the stuff.
I appreciate that you are skeptical. Can you post any facts or first hand information that AMSOIL does not meet their claims?
I am convinced of the benefits of full synthetic. I also have seen great test results on Mobil 1 ATF and Redline ATF. I just like fact that the other "stuff" comes delivered to the door; not even going to type the name again.
Rusty,
Thanks for the "friendly" warning. I think I see where it is coming from now. You could have pointed me to the top post on the forum and I wouldn't have questioned your further.
Since we already have the thread going...
I will be doing the fluid/filter change myself and have a good method to clear out the cooling lines. That may make it even harder to prove things were done right, I agree. But here's the thing with that: manufacturer's seem to brainwash people into believing that doing their own maintenance will void the warranty, or not using their brand oil. It is not true and there are laws preventing manufacturers from voiding your warranty for such. The burden of proof is on them. Anyway, my Ford dealership (and most I've dealt with) loves to do warranty work. They get guaranteed payment without customer hassle for things like unnecessary work and pricing.
