86 f150 302 code 22r?
Old Oct 25, 2024 | 05:13 PM
fordtruck1986's Avatar
fordtruck1986
1st Gear
I got in my truck today and it was running like crap. Assumed it was the throttle position module since i had issues in the past with it. Adjusted it and still ran crappy. Did an obd KEOR test and threw a code 22r. Went out and bought a new map sensor, same issue and same code, went out and refueled the truck, 25 minute drive to and fro, same issues and same code, any ideas?
Old Oct 25, 2024 | 09:26 PM
diggerrigger's Avatar
diggerrigger
Originally Posted by fordtruck1986
any ideas?
Check MAP voltage. With key on orange wire should have about 5v, one of the other two (the one with blue, maybe green I think) should have 2.5v. Since you got 22 on the KOER test, check the EGR valve for leaking issue. Unbolt the EGR from the manifold and blank it off with a home made blank.
Shag from WA
1983 - 2012 Ranger & B-Series
Sep 25, 2023 03:45 AM
jzman7
Aug 12, 2007 03:38 PM
Peter94
Jan 6, 2005 12:53 PM
Adrienc9
Mar 30, 2004 07:09 AM
