Intake plenum gasket?
Old Oct 25, 2024 | 04:30 PM
BenRod's Avatar
BenRod
Has anyone used the cometic gasket for the intake plenums? Just did a set on an early 99 with the flat aluminum style plenums but only have about a month on them so far. Does anyone think it's a bad idea ?
Old Oct 25, 2024 | 07:25 PM
Edgethis's Avatar
Edgethis
If your plenums are in good shape those gaskets should work fine. But I see alot of folks mangling the plenums when removing, plus when scraping the old sealant off.
Old Oct 25, 2024 | 09:58 PM
BenRod's Avatar
BenRod
I don't know that I would trust a gasket with the stock plenums myself
Old Oct 28, 2024 | 08:54 AM
knottyrope's Avatar
knottyrope
stock plenums need to be glued with Ford TA since the metal is too thin for the boost pressures with gasket
Old Feb 18, 2025 | 12:30 PM
budweiser-obs's Avatar
budweiser-obs
1st Gear
What about using the cometic gasket when upgrading to 3” cnc fabrication plenums? What’s pros/cons of gasket over sealant
Old Feb 18, 2025 | 02:31 PM
knottyrope's Avatar
knottyrope
When using TA, you have .050 or less of material (that is like glue) bonding the two pieces together to hold 30+ PSI of boost
IMO oring sealed before gasket sealed when dealing with pressure
RiffRaff makes oring sealed intake plenums
Old Feb 18, 2025 | 03:03 PM
BenRod's Avatar
BenRod
so I have a buddy that used the cometic gasket with the upgraded intake plenums. So far so good. We did it a little after i posted this forum. Still good
Old Nov 12, 2025 | 01:53 PM
BenRod's Avatar
BenRod
still havent fpund a real answer.
Old Nov 12, 2025 | 02:26 PM
knottyrope's Avatar
knottyrope
try a gasket and see
old post
https://www.ford-trucks.com/forums/1...m-gaskets.html
I know the Sealant will work.
snip
Old Nov 30, 2025 | 05:00 AM
BenRod's Avatar
BenRod
old post
snip
THEY PAIR THE PLENUMS WITH THE COMETIC GASKET NOW
Old Dec 1, 2025 | 08:51 AM
knottyrope's Avatar
knottyrope
link for that?
Old Dec 1, 2025 | 09:32 AM
BenRod's Avatar
BenRod
link for that?
I dont know how to do that. Its on cncfabs website. They have had good luck with it. Many others have also.
Old Dec 1, 2025 | 06:25 PM
97-psd's Avatar
97-psd
Got curious.
https://cncfab.us/products/94-5-98-5...plenums-423004
the plenums come with RTV. You can buy the gaskets as well, but they come with rtv as the standard option
Old Dec 1, 2025 | 08:23 PM
BenRod's Avatar
BenRod
Originally Posted by 97-psd
Got curious.
However youd like to word it. They both work
Old Dec 1, 2025 | 09:25 PM
97-psd's Avatar
97-psd
you are correct. They will both work. I do think it is worth noting that RTV is their standard option, but you can upgrade and include the gaskets as your discretion. I would take that as an indication that the gaskets would do well.
with new billet plenums, you can probably use either one. With the thin stock plenums, I would probably lean towards the RTV. Either way, a clean mounting surface is crucial to making either one work.
