2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
Rotational thump help
Old Oct 24, 2024 | 10:08 PM
Icculus's Avatar
Icculus
Wife’s 2015 eco boost EL. Move steering wheel all the way to the right and I get a rotational bump/thump.
Ive jacked it up, and tested each side by grabbing each tire at 12/6 and 9/3, nothing is loose.
put a steel pole under tire and lifted up, no popping.
ball joints and tie rods show no cracking etc.
other thoughts?
Old Oct 25, 2024 | 12:24 AM
85e150's Avatar
85e150
Rack and pinion steering?
If so, could be rack trouble.
Old Oct 25, 2024 | 05:59 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I'd be checking for something that the tire could be touching at full lock if it seems to be rotational. Jack up the front end, turn the wheel fully to the right, and spin the tires, see if you can see anything touching. My money would be on a just barely loose fender liner or damaged mudflap, I had this issue on an older SD that someone ran too big of a tire on and tore the inner fender liner, had to pull it up and fix it.
BioBuner
Mar 7, 2011 05:59 AM
Lawdogiii
1997 - 2003 F150
Aug 12, 2010 08:36 AM
Ford-Trucker84537
Aug 24, 2007 06:42 PM
HIDEE101
Feb 8, 2005 08:10 PM
napfam5
Aerostar
Jun 23, 2004 03:17 PM
