KLM Performance brake lines
Old Nov 7, 2024 | 05:01 PM
acdii's Avatar
acdii
Originally Posted by HRTKD
That was precisely the topic of the conversation I had with the engineer. He, more or less, said that the braiding shouldn't make a difference at all and if it did you have some lousy rubber lines.
More than likely he was thinking NEW lines. Age these lines by 20 years and things change. The braided lines 20 years from now will hold higher pressures due to the braiding staying strong and preventing the old rubber from flexing.
Old Nov 8, 2024 | 03:02 AM
Euroman's Avatar
Euroman
How long do the standard lines last? On my 6.0 I had to change them out after 12 years as they had started to delaminate - braking was ok, but the fluid couldn’t return and the brakes kept overheating.
it doesn’t seem to be a problem in Europe - my local garage had never heard of it before, and my mini lines are 18 years old, 180k miles and still all original.
Old Nov 8, 2024 | 08:58 AM
HRTKD's Avatar
HRTKD
In my opinion, replacing the rubber brake lines is not very common. I had a '91 Ford Ranger that would have needed new metal brake lines soon due to internal rusting, but the rubber lines were OK. The vehicle started out in Hawaii and was later shipped to Colorado. It was poorly maintained by the original owner.
Old Nov 8, 2024 | 11:39 AM
acdii's Avatar
acdii
Depends on the environment they are used in. Up in the salt belt, the chemicals used on roads can breakdown the rubber shell and cause it to crack and split, which then attacks the polyester fibers that create the barrier to hold in the pressure and eventually cause the hose to rupture. Improper care of the brake system such as never changing the brake fluid can cause the rubber inside the lines to deteriorate and create blockages as you mention.
Old Nov 8, 2024 | 12:20 PM
Euroman's Avatar
Euroman
if was something the 6.0 forum was well aware of, maybe a poor batch? My 6.0 was owned by a trucking company for many years before I bought it and the foreman seemed to be over rather than under maintaining it, but maybe it’s something he overlooked.
In any case, good to know it’s rare.
Old Nov 11, 2024 | 12:17 PM
Overkill2's Avatar
Overkill2
It will be almost impossible to get an apples-to-apples comparison. When you replace a brake line you'll have to bleed the brakes. That right there makes a change to the system that affects pedal feel. You would also likely flush the brake fluid, and that also throws off the comparison. Nonetheless, if you saw a 2x performance change in braking, I would say that your brake fluid was really bad to start with or the engineer I talked to gave me bad information.
Oh I'm sure... I can't remember what I did last week.
Yep, more line bleeding to do for sure...
As to pedal feel, don't think it was bad prior to the one front side going metal to metal from seized caliper pins...
Old Nov 11, 2024 | 12:18 PM
Overkill2's Avatar
Overkill2
Mine definitely had cracks on them in the front... not sure on the rears...
idhiboy
2015 - 2020 F150
May 14, 2023 08:54 AM
bjmayberry2
20
Jul 25, 2022 07:04 PM
Grubbworm
Projects
225
Sep 11, 2016 07:40 PM
dmccorkle911
Missouri Chapter
May 11, 2016 01:59 PM
Red Ford Truck
Ontario Chapter
Jul 16, 2010 08:27 PM
