Engine block heater
Old Oct 17, 2024 | 02:41 PM
Obelix's Avatar
Obelix
4th Gear
Engine block heater
Hi
2024 F350 7.3
Plan to go to Canada in Dec, do I need an engine block heater?
Please advise
Thanks
Old Oct 17, 2024 | 02:53 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Only if you need the heater to work quickly after starting it.
It isn't like a diesel that needs cylinder heat to work well.
Old Oct 17, 2024 | 02:56 PM
Obelix's Avatar
Obelix
4th Gear
Thanks for the reply, appreciated.
Old Oct 17, 2024 | 03:00 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Now, I will add, that you need to make sure the antifreeze mixture level is proper for the temps your truck will see.
Old Oct 17, 2024 | 03:13 PM
Obelix's Avatar
Obelix
4th Gear
Okay, I will google that, Never travelled to where it is this cold.
Old Oct 17, 2024 | 03:28 PM
westracing01's Avatar
westracing01
Canada is a big place... Where in Canada are you going and how cold are you expecting it? Toronto in December is a helluva lot different than Edmonton.
Old Oct 17, 2024 | 04:30 PM
DPelletier's Avatar
DPelletier
Yep; Victoria B.C. or Tuktoyaktuk in the Northwest Territories - big difference. ;-) Many parts of Canada are warmer and more temperate than some of the northern continental US states.
Dave
Old Oct 17, 2024 | 08:03 PM
Chris 86's Avatar
Chris 86
My f-350 has gone through 4 canadian winters now. I only just discovered it has a block heater. Never once had an issue starting.
Old Oct 17, 2024 | 10:14 PM
Flatland1's Avatar
Flatland1
Don't forget anti gel for the fuel................
Old Oct 17, 2024 | 10:54 PM
muisejt's Avatar
muisejt
not needed if you buy fuel in Canada, we got winter blend up here
Old Oct 17, 2024 | 10:57 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Plus, the OP has a gas engine truck, no anti-gel needed.
Old Oct 17, 2024 | 11:02 PM
2021F350's Avatar
2021F350
and... That would have depended on where in Canada you spent your winter... I can assure you, that if you would have been in some of the places I have spent my winters, you would have trouble starting your truck even when it was plugged in, extra inline heaters and battery blankets were a must, or you would NOT be going anywhere in the morning...
Old Oct 18, 2024 | 05:37 AM
Chris 86's Avatar
Chris 86
Sounds like you are in the oil fields. I'm eastern Ontario. It gets cold, But usually not more then -35'c.
Old Oct 18, 2024 | 05:57 AM
Obelix's Avatar
Obelix
4th Gear
Hi, I am going to Winnipeg
Old Oct 18, 2024 | 07:53 AM
'65Ford's Avatar
'65Ford
Where it's real cold, the tank style block heaters work better than the typical block heater because they run more watts while circulating water in the block. Trick is finding a way to plumb them.
Remember to used the low temp window washer fluid.
